I created a symbolic link for apache2 like
srv ->/m/srv
where /m/srv is a separate filesystem.
Also changed apache /etc/default-server.conf to allow symlinks; e.g.
Options FollowSymLinks SymLinksifOwnerMatch
Apache seems to work, at least in it's simplest form - I get "It Works" when I go to the website.
But Zoneminder is failing with a "Access forbidden", Error 403 when I try to go to the ZM console.
Looked in the ZM Options but didn't see anything to do with symlinks.
I see this in my /var/log/error_log:
[Wed Apr 08 20:36:09 2009] [error] [client 192.168.6.2] Symbolic link not allowed or link target not accessible: /srv, referer: http://myth/zm/
Seems there must be something else to set - either in Apache or ZM.
Any ideas?
Jim
symbolic causes zm to fail
If you cant figure it out, instead of using a symlink you can do this:
mount --bind /some/source/dir /some/destination/dir
It will give you the same effect as a hard link, except it works across filesystems unlike the ln command. This uses a new feature in 2.6 kernel that lets you mount any part of a filesystem onto any part of any other filesystem. It will not appear as a symlink and the only way you will see it is if you type "mount"
If you want this to be permanent (survive a reboot) you can put it in your fstab like so:
/dir1 /dir2 none bind
