Zoneminder 1.23.3 worked perfectly for me ... none of my installs work with 1.24.1, zmc always crashes:
04/10/09 16:38:41.088263 zmc_dvideo0[-1].INF-zm_debug.c/292 [New Debug Level = 3
, New Debug Log = /tmp/zm_debug.log.17667]
04/10/09 16:38:41.089053 zmc_dvideo0[-1].DB1-zm_monitor.cpp/1708 [Got 1 monitors
04/10/09 16:38:41.089139 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/287 [V4L2 suppo
rt enabled, using V4L2 api]
04/10/09 16:38:41.089573 zmc_dvideo0[-1].DB1-zm_monitor.cpp/338 [monitor purpose
=1]
04/10/09 16:38:41.089605 zmc_dvideo0[-1].DB1-zm_monitor.cpp/345 [mem.size=921752
4]
04/10/09 16:38:41.095410 zmc_dvideo0[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/
All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3
x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
04/10/09 16:38:41.096845 zmc_dvideo0[-1].DB1-zm_monitor.cpp/458 [Monitor New has
function 4]
04/10/09 16:38:41.096867 zmc_dvideo0[-1].DB1-zm_monitor.cpp/459 [Monitor New LBF
= '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
04/10/09 16:38:41.096884 zmc_dvideo0[-1].DB1-zm_monitor.cpp/460 [Monitor New IBC
= 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
04/10/09 16:38:41.097330 zmc_dvideo0[-1].DB1-zm_zone.cpp/889 [Got 1 zones for mo
nitor New]
04/10/09 16:38:41.097369 zmc_dvideo0[-1].DB3-zm_zone.cpp/758 [Parsing polygon st
ring '0,0 319,0 319,239 0,239']
04/10/09 16:38:41.097387 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0
from polygon string]
04/10/09 16:38:41.097548 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 319
,0 from polygon string]
04/10/09 16:38:41.097563 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 319
,239 from polygon string]
04/10/09 16:38:41.097578 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,2
04/10/09 16:38:41.097595 zmc_dvideo0[-1].DB3-zm_zone.cpp/816 [Successfully parse
d polygon string]
04/10/09 16:38:41.097612 zmc_dvideo0[-1].DB1-zm_zone.cpp/50 [Initialised zone 1/
All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB
:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0, OF: 0]
04/10/09 16:38:41.099023 zmc_dvideo0[-1].DB1-zm_monitor.cpp/1810 [Loaded monitor
1(New), 1 zones]
04/10/09 16:38:41.099043 zmc_dvideo0[-1].INF-zmc.cpp/186 [Starting Capture]
04/10/09 16:38:41.099117 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/350 [Opening vi
deo device /dev/video0]
04/10/09 16:38:41.099174 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/356 [V4L2 suppo
04/10/09 16:38:41.099190 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/361 [Checking v
ideo device capabilities]
04/10/09 16:38:41.099214 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/371 [Setting up
video format]
04/10/09 16:38:41.099251 zmc_dvideo0[-1].FAT-zm_local_camera.cpp/387 [Failed to
set video format: Invalid argument]
04/10/09 16:38:41.099380 zmc_dvideo0[-1].INF-zm_signal.cpp/64 [Got signal 6 (Abo
rted), exiting and forcing backtrace]
04/10/09 16:38:41.099417 zmc_dvideo0[-1].ERR-zm_signal.cpp/90 [Signal address is
0x206, no eip]
04/10/09 16:38:41.099660 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib6
4/libpthread.so.0 [0x2aaaaacec4c0]]
04/10/09 16:38:41.099697 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib6
4/libc.so.6(gsignal+0x35) [0x3acda30215]]
04/10/09 16:38:41.099725 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib6
4/libc.so.6(abort+0x110) [0x3acda31cc0]]
04/10/09 16:38:41.099752 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/
local/bin/zmc [0x40d69e]]
04/10/09 16:38:41.099780 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/
local/bin/zmc [0x41c265]]
04/10/09 16:38:41.099807 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/
local/bin/zmc [0x41c68d]]
04/10/09 16:38:41.099833 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/
local/bin/zmc [0x404ee5]]
04/10/09 16:38:41.099859 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib6
4/libc.so.6(__libc_start_main+0xf4) [0x3acda1d974]]
04/10/09 16:38:41.099889 zmc_dvideo0[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/
local/bin/zmc(__gxx_personality_v0+0x1d9) [0x404a89]]
04/10/09 16:38:41.099929 zmc_dvideo0[-1].INF-zm_signal.cpp/125 [Backtrace comple
te, please execute the following command for more information]
04/10/09 16:38:41.100842 zmc_dvideo0[-1].INF-zm_signal.cpp/126 [addr2line -e /us
r/local/bin/zmc(__gxx_personality_v0+0x1d9) 0x2aaaaacec4c0 0x3acda30215 0x3acda3
1cc0 0x40d69e 0x41c265 0x41c68d 0x404ee5 0x3acda1d974 0x404a89]
ZMU shows :
Video Capabilities
Name: BT878 video (ProVideo PV143)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
I am running Centos 5.3
Zmc Error
Re: Zmc Error
ddalton wrote: 04/10/09 16:38:41.099929 zmc_dvideo0[-1].INF-zm_signal.cpp/125 [Backtrace comple
All I get when I run the command in the brackets is :
addr2line -e /usr/local/bin/zmc
(__gxx_personality_v0+0x1f9) 0x3bc780de70 0x3bc6c30155 0x3bc6c31bf0 0x40d78e 0x41ba
??:0
I assume I am not properly using the command. I did re install 1.23.3 and it works perfectly
I still have two broken 1.24.1 installs all with the same errors
??:0
- zoneminder
- Site Admin
- Contact:
