FPS too low and changing frequently
Posted: Wed Apr 15, 2009 8:16 pm
I have a ZM server based on a P4 1.7Ghz with 512Mb of ram.
It has 2 cameras (USB Creative Live!). One runs at 640x480 5fps stable(monitor) and the second one is set at the same resolution but the FPS varies between 10 to 20fps (motion detection).
The loadq is 0.90 while the CPU usage is 42%.
34.3%us, 0.7%sy, 0.0%ni, 58.5%id, 0.0%wa, 0.0%hi, 6.5%si, 0.0%st
Is it normal that one has much lower FPS than the other one ? Are these stats consistent with the hardware and usage ? I find that the load is high for that type of usage, do you agree ?
What can I do to improve the FPS ?
I have noticed most of you seem to be using a low fps. I'm trying to get a high one since low FPS gives me blurry pictures and faces are not recognizable. Are there other way to make the jpgs clearer in low fps situations ? (beside increasing the quality factor)
Thanks,
Chandi
Thanks,
Chandi
