Generate video in SVN
Posted: Thu Apr 16, 2009 1:30 pm
It could be just me but I'm finding the current SVN version of Zoneminder and Ffmpeg unable to generate videos. I just get the failed to generate video display. I log is created for the event but I'm not sure what to make of it.
[mjpeg @ 0x9dfb070]marker=c4 avail_size_in_buf=16295
[mjpeg @ 0x9dfb070]class=1 index=1 nb_codes=251
[mjpeg @ 0x9dfb070]marker parser used 181 bytes (1448 bits)
[mjpeg @ 0x9dfb070]marker=da avail_size_in_buf=16112
[mjpeg @ 0x9dfb070]escaping removed 44 bytes
[mjpeg @ 0x9dfb070]component: 0
[mjpeg @ 0x9dfb070]component: 1
[mjpeg @ 0x9dfb070]component: 2
[mjpeg @ 0x9dfb070]marker parser used 16067 bytes (128536 bits)
[mjpeg @ 0x9dfb070]marker=d9 avail_size_in_buf=0
[mjpeg @ 0x9dfb070]mjpeg decode frame unused 0 bytes
Input #0, image2, from '%03d-capture.jpg':
Duration: 00:00:26.50, start: 0.000000, bitrate: N/A
Stream #0.0, 1/4: Video: mjpeg, yuvj420p, 320x240 [PAR 1:1 DAR 4:3], 1/4, 4 tbr, 4 tbn, 4 tbc
Output #0, mpeg, to 'Event-53-r1-s1.mpeg':
Stream #0.0, 1/90000: Video: mpeg1video, yuv420p, 320x240 [PAR 1:1 DAR 4:3], 1/25, q=2-31, 200 kb/s, 90k tbn, 25 tbc
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
/usr/local/bin/ffmpeg: symbol lookup error: /usr/local/bin/ffmpeg: undefined symbol: avcodec_decode_video2
Stream mapping:
Stream #0.0 -> #0.0
