Page 1 of 1
zm on mobile devices
Posted: Sun Apr 19, 2009 4:15 am
by souverain
I have been looking for this info for a long time, and now that I found an acceptablyworking config, I like to share it:
on windows mobile 6.1, you can get zm very close to streaming using the following settings:
-use iris browser
- remove cambozola
-set update on low BW to 1 sec - so we are not really streaming
-set fps to a high number, say 30 fps
It looks very very close to live streaming - the delay is literally half a second.
if you get this working also, let me know.
Posted: Mon Apr 20, 2009 1:08 pm
by punk_ecas
Currently i'm working on a stand alone ZM client for Windows Mobile.
At the moment i already have a prototype with good results on video streaming.
In my plans I guess that after the middle of the next month I will get a beta version.
About your suggestion, did you tried it with sprint EVDO?
Soon you will be notified to test my application.
Posted: Tue Apr 21, 2009 11:04 am
by kevin_robson
Thanks to both of you. I'd also be interested in seeing the windows mobile client when the beta is ready.
I'll give the initial settings a go in the meanwhile.
Posted: Wed Apr 22, 2009 11:55 am
by kevin_robson
souverain,
Thanks for the tip re iris. I quite like it.
I have followed your stuff and have streaming (well sort of) on live view on 1.23.1
Is there a way to be able to view streaming of past events this way - the event view just brings up still pics with the option to generate an mpeg - no image streaming.
Also, I'm just using the standard URL to access - should I be using the xhtml switch?
Thanks though - this is a big improvement on what I've had previously.
Posted: Thu Apr 23, 2009 3:21 am
by souverain
punk_ecas:
Yes, I am on Sprint EVDO. Sprint Coverage tends to be spotty, but where there is good signal, the EVDO is very usable with zm.
Kevin:
Yes, it is not actually streaming - it is a snapshot every second, but I think it is still useful for many applications since it captures a whole range of motions (will not capture someone running fast past the camera view).
And, not, I have experimented with various formats, but it still cannot view saved events.
Posted: Thu Apr 23, 2009 6:25 am
by kevin_robson
OK, thanks for the reply. I just wanted to check I wasn't missing something re the recorded events. As you say it is better than what I have had before.
Posted: Tue Sep 29, 2009 9:39 pm
by kevin_robson
Found this web browser that supports jpeg streaming.
http://www.skyfire.com/
Seems to work quite well with limited testing
Posted: Thu Oct 01, 2009 2:32 am
by mrd
Please post when you get the zm client ready to test.
Posted: Thu Oct 01, 2009 6:46 am
by kevin_robson
There is nothing to get ready, its just a web broweser for windows mobile devices. But it seems to be compatible with zm and zm streams.
To my knowledge this isn't directly possible with other WM browsers, as per the previous posts.
