Replay All Events
zhenxu_zj
Replay All Events
Post by zhenxu_zj »
I have ZM 1.24.1. I am not sure how the replay all events works. Any help is appreciated...
Single event playback works fine and stops at the end of the event.
Gapless event playback works and loops all events without pause.
All events playback is acting funny. It will stop at a black screen with a message "Time to next event nnn seconds". No matter how long I wait, it will never advance to the next event. I am on Firefox.
Thanks!
dariush
Post by dariush »
Hi, have you solved the problem?
I'm facing the same behaviour.
Any suggestion?
Best regards,
Dariush.
startrk
Solved issue for me.
Post by startrk »
For all the
"Time to next event = xx seconds"
It only happened on the Bluecherry PV-149 cards. The Axis cameras or any IP camera does not do the same.
What the issue was I increased the buffers to the following
Image Buffer Size 60
Warmup Frames 25
Pre Event IC 60
Post Event IC 90
Stream Replay IB 1000
Alarm Frame Count 2
When I had those settings the PV-149's event playbacks would always have the "Time to next event = 2 seconds". As soon as I switch it to:
Image Buffer Size 40
Warmup Frames 25
Pre Event IC 30
Post Event IC 60
Alarm Frame Count 2
All those errors ceased and now playback works perfectly.
Hope that helps someone.
