instale zm en debian y resulto todo bien solo este error..
alguien sabe porque susede
gracias
Table 'zm.Config' doesn't exist
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /var/www/zm/includes/config.php on line 144
Notice: Use of undefined constant ZM_OPT_USE_AUTH - assumed 'ZM_OPT_USE_AUTH' in /var/www/zm/index.php on line 87
Notice: Use of undefined constant ZM_LANG_DEFAULT - assumed 'ZM_LANG_DEFAULT' in /var/www/zm/includes/lang.php on line 29
Notice: Use of undefined constant ZM_OPT_USE_AUTH - assumed 'ZM_OPT_USE_AUTH' in /var/www/zm/includes/actions.php on line 35
Notice: Use of undefined constant ZM_AUTH_HASH_LOGINS - assumed 'ZM_AUTH_HASH_LOGINS' in /var/www/zm/includes/actions.php on line 35
Notice: Use of undefined constant ZM_AUTH_TYPE - assumed 'ZM_AUTH_TYPE' in /var/www/zm/includes/actions.php on line 46
Notice: Use of undefined constant ZM_AUTH_TYPE - assumed 'ZM_AUTH_TYPE' in /var/www/zm/includes/functions.php on line 43
Notice: Use of undefined constant ZM_AUTH_RELAY - assumed 'ZM_AUTH_RELAY' in /var/www/zm/includes/functions.php on line 59
An error has occurred and this operation cannot continue.
For full details check your web logs for the code '2FCAFF'
