Page 1 of 1
DCS-3410 and No RTSP sources
Posted: Wed Apr 29, 2009 7:31 pm
by hville
Heya guys!
Been trying to get zoneminder up and going using the 8.10 Vanilla guide.
Everything seems to be installed and running ok but I'm having trouble getting anything from my cameras.
Has anyone had any luck getting D-Link DCS-3410 ip cameras working with zoneminder?
Going to try the aclocal suggestion mentioned in another thread next chance i get.
Can view the camera stream with VLC via RTSP://IP.ADDY/play3.sdp
Thanks for any help you can offer folks.
Posting relevant log entries below.
-------------messages------------
Apr 29 13:22:57 newcamera-server zmdc[5182]: INF [Starting pending process, zmc -m 3]
Apr 29 13:22:57 newcamera-server zmdc[5182]: INF ['zmc -m 3' starting at 09/04/29 13:22:57, pid = 8785]
Apr 29 13:22:57 newcamera-server zmdc[8785]: INF ['zmc -m 3' started at 09/04/29 13:22:57]
Apr 29 13:22:57 newcamera-server zmc_m3[8785]: INF [Debug Level = 0, Debug Log = <none>]
Apr 29 13:22:57 newcamera-server zmc_m3[8785]: INF [Starting Capture]
Apr 29 13:23:02 newcamera-server zmc_m3[8785]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Apr 29 13:23:02 newcamera-server zmc_m3[8785]: INF [Backtrace complete, please execute the following command for more information]
Apr 29 13:23:02 newcamera-server zmc_m3[8785]: INF [addr2line -e /usr/local/bin/zmc 0xb80e0430 0xb80e0430 0xb71a3880 0xb71a5248 0x80562bd 0x80814c4 0x804d08b 0xb718e685 0x804cbf1]
-----------------zdmc.log-----------
04/29/09 13:22:57.071211 zmdc[5182].INF [Starting pending process, zmc -m 3]
04/29/09 13:22:57.072389 zmdc[5182].INF ['zmc -m 3' starting at 09/04/29 13:22:57, pid = 8785]
04/29/09 13:23:02.125566 zmdc[5182].ERR ['zmc -m 3' exited abnormally, exit status 6]
----------------------addr2line--------------
??:0
??:0
??:0
??:0
??:0
/usr/src/zm/src/zm_remote_camera_rtsp.cpp:118
/usr/src/zm/src/zmc.cpp:199
??:0
??:0
Debug Level 1
04/29/09 13:38:28.091353 zmc_m3[9778].INF-zm_debug.c/292 [New Debug Level = 1, New Debug Log = /tmp/zm_debug.log.09778]
04/29/09 13:38:28.091609 zmc_m3[9778].DB1-zm_monitor.cpp/2264 [Got 1 monitors]
04/29/09 13:38:28.091997 zmc_m3[9778].DB1-zm_thread.cpp/240 [Creating thread]
04/29/09 13:38:28.092085 zmc_m3[9778].DB1-zm_thread.cpp/276 [Starting thread]
04/29/09 13:38:28.092219 zmc_m3[9778].DB1-zm_thread.cpp/297 [Started thread 9780]
04/29/09 13:38:28.093064 zmc_m3[9778].DB1-zm_monitor.cpp/338 [monitor purpose=1]
04/29/09 13:38:28.093084 zmc_m3[9778].DB1-zm_monitor.cpp/345 [mem.size=10138792]
04/29/09 13:38:28.104130 zmc_m3[9778].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 352x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
04/29/09 13:38:28.106761 zmc_m3[9778].DB1-zm_monitor.cpp/458 [Monitor Monitor-3 has function 2]
04/29/09 13:38:28.106777 zmc_m3[9778].DB1-zm_monitor.cpp/459 [Monitor Monitor-3 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
04/29/09 13:38:28.106792 zmc_m3[9778].DB1-zm_monitor.cpp/460 [Monitor Monitor-3 IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
04/29/09 13:38:28.106966 zmc_m3[9778].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Monitor-3]
04/29/09 13:38:28.106997 zmc_m3[9778].DB1-zm_zone.cpp/50 [Initialised zone 3/All - 1 - 352x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2534, MxAP:63360, FB:3x3, MnFP:2534, MxFP:63360, MnBS:1689, MxBS:0, MnB:1, MxB:0, OF: 0]
04/29/09 13:38:28.109604 zmc_m3[9778].DB1-zm_monitor.cpp/2463 [Loaded monitor 3(Monitor-3), 1 zones]
04/29/09 13:38:28.109625 zmc_m3[9778].INF-zmc.cpp/188 [Starting Capture]
04/29/09 13:38:33.115678 zmc_m3[9778].FAT-zm_remote_camera_rtsp.cpp/118 [No RTSP sources]
04/29/09 13:38:33.115958 zmc_m3[9778].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
04/29/09 13:38:33.116084 zmc_m3[9778].ERR-zm_signal.cpp/84 [Signal address is (nil), from 0xb7f76430]
04/29/09 13:38:33.116462 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: [0xb7f76430]]
04/29/09 13:38:33.116563 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: [0xb7f76430]]
04/29/09 13:38:33.116645 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(gsignal+0x50) [0xb7039880]]
04/29/09 13:38:33.116744 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(abort+0x188) [0xb703b248]]
04/29/09 13:38:33.116835 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x80562bd]]
04/29/09 13:38:33.116957 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x80814c4]]
04/29/09 13:38:33.117049 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804d08b]]
04/29/09 13:38:33.117141 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5) [0xb7024685]]
04/29/09 13:38:33.117231 zmc_m3[9778].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804cbf1]]
04/29/09 13:38:33.117320 zmc_m3[9778].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
04/29/09 13:38:33.117420 zmc_m3[9778].INF-zm_signal.cpp/126 [addr2line -e /usr/local/bin/zmc 0xb7f76430 0xb7f76430 0xb7039880 0xb703b248 0x80562bd 0x80814c4 0x804d08b 0xb7024685 0x804cbf1
Posted: Fri Jan 22, 2010 7:11 pm
by BlankMan
Got a DCS-3410 got it working streaming. Added it to the D-Link camera list here:
http://www.zoneminder.com/wiki/index.ph ... k#DCS-3410
Posted: Tue Mar 16, 2010 2:12 am
by BlankMan
I did get my DCS-3410 working pulling an RTSP stream at 30fps using ffmpeg as the 'Source Type'. I updated the camera in the WiKi with the config.
