So, should I change the camera setup to something like, "no motion detection"?
-Gian
p.s. maybe you can give me a hint: events are recorded (I can directly access the files), however I can't see them in the console, it just shows a broken icon.
most likely its a permissions issue. Make sure the events folder and sub folders are atleast 711, and the images are 644. If you start zoneminder or apache under a umask other than 0022 it can create them also with wrong permissions.
