controls not working in Montage view
carlo1973
Post by carlo1973 »
Hi there. Not sure what happend. Everything was working okay on friday, came back to work after the weekend and the Controls function in Montage view stopped working. Just a note - in WATCH mode everything is working just fine. Its only in Montage view that the controls stopped working.
When I select one of my monitors, it flips back and defaults back to the first monitor. Clicking on any of the controls does nothing. I upped my debug level to 5 and here is the results I am seeing:
05/04/09 11:51:29.627385 zmf_m4[-1].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.05976]
05/04/09 11:51:29.627613 zmf_m4[-1].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
05/04/09 11:51:29.629530 zmf_m4[-1].DB1-zm_monitor.cpp/338 [monitor purpose=0]
05/04/09 11:51:29.629555 zmf_m4[-1].DB1-zm_monitor.cpp/345 [mem.size=18433204]
05/04/09 11:51:29.629630 zmf_m4[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
05/04/09 11:51:29.634843 zmf_m4[-1].DB1-zm_monitor.cpp/458 [Monitor Front-Hall has function 3]
05/04/09 11:51:29.634864 zmf_m4[-1].DB1-zm_monitor.cpp/459 [Monitor Front-Hall LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
05/04/09 11:51:29.634877 zmf_m4[-1].DB1-zm_monitor.cpp/460 [Monitor Front-Hall IBC = 20, WUC = 15, pEC = 5, PEC = 5, EAF = 1, FRI = 1000, RBP = 7, FM = 1]
05/04/09 11:51:29.634898 zmf_m4[-1].DB1-zm_monitor.cpp/2457 [Loaded monitor 4(Front-Hall), 0 zones]
05/04/09 11:51:30.765385 zmf_m4[-1].INF-zmf.cpp/86 [Frame server socket open, awaiting images]
05/04/09 11:51:31.765948 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:32.765076 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:33.763872 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:34.765401 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:35.765645 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:36.766954 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:37.767235 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:38.767990 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:39.769338 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:40.769903 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:41.770820 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:42.768331 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:43.768349 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:44.773962 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:45.775132 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:46.776084 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:47.780344 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:48.777295 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:49.777212 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:50.778375 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:51.779125 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:52.779608 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:53.780060 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:54.780237 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:55.777095 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:56.777301 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:57.781589 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:58.782229 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:51:59.782841 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:00.787391 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:01.788146 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:02.788840 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:03.789409 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:04.788616 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:05.788232 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:06.789109 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:07.789469 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:08.786677 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:09.787498 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:10.786535 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:11.787382 zmf_m4[-1].DB1-zmf.cpp/200 [Select timed out]
05/04/09 11:52:12.791571 zmf_m4[-1].DB1-
zmcontrol.log
05/04/09 10:10:18.611888 zmcontrol[4473].FAT [Can't access moveStop member of object of class ZoneMinder::Control::PanasonicIP]
05/04/09 10:10:19.285018 zmcontrol[4665].INF [Starting control server 3/PanasonicIP]
05/04/09 10:10:19.287220 zmcontrol[4666].INF [Control server 3/PanasonicIP starting at 09/05/04 10:10:19]
05/04/09 10:28:49.977264 zmcontrol[4060].INF [Control server 2/PanasonicIP exiting at 09/05/04 10:28:49]
05/04/09 10:30:43.980407 zmcontrol[4064].INF [Control server 4/PanasonicIP exiting at 09/05/04 10:30:43]
05/04/09 10:40:58.651919 zmcontrol[4666].INF [Control server 3/PanasonicIP exiting at 09/05/04 10:40:58]
05/04/09 10:52:47.989611 zmcontrol[5247].INF [Starting control server 2/PanasonicIP]
05/04/09 10:52:47.991769 zmcontrol[5248].INF [Control server 2/PanasonicIP starting at 09/05/04 10:52:47]
05/04/09 10:58:21.169440 zmcontrol[5323].INF [Starting control server 3/PanasonicIP]
05/04/09 10:58:21.171555 zmcontrol[5324].INF [Control server 3/PanasonicIP starting at 09/05/04 10:58:21]
05/04/09 10:58:22.182805 zmcontrol[5324].FAT [Can't access reset member of object of class ZoneMinder::Control::PanasonicIP]
05/04/09 10:58:26.476183 zmcontrol[5325].INF [Starting control server 3/PanasonicIP]
05/04/09 10:58:26.478436 zmcontrol[5326].INF [Control server 3/PanasonicIP starting at 09/05/04 10:58:26]
05/04/09 10:58:27.491569 zmcontrol[5326].FAT [Can't access reset member of object of class ZoneMinder::Control::PanasonicIP]
05/04/09 10:58:27.691176 zmcontrol[5327].INF [Starting control server 3/PanasonicIP]
05/04/09 10:58:27.693055 zmcontrol[5328].INF [Control server 3/PanasonicIP starting at 09/05/04 10:58:27]
05/04/09 10:58:28.698388 zmcontrol[5328].FAT [Can't access reset member of object of class ZoneMinder::Control::PanasonicIP]
05/04/09 10:58:31.582455 zmcontrol[5329].INF [Starting control server 3/PanasonicIP]
05/04/09 10:58:31.584565 zmcontrol[5330].INF [Control server 3/PanasonicIP starting at 09/05/04 10:58:31]
05/04/09 10:58:32.597767 zmcontrol[5330].FAT [Can't access reset member of object of class ZoneMinder::Control::PanasonicIP]
05/04/09 11:00:15.943008 zmcontrol[5360].INF [Starting control server 4/PanasonicIP]
05/04/09 11:00:15.945108 zmcontrol[5361].INF [Control server 4/PanasonicIP starting at 09/05/04 11:00:15]
05/04/09 11:00:17.151804 zmcontrol[5361].ERR [Error check failed: '400 Page not found']
05/04/09 11:00:52.079421 zmcontrol[5361].ERR [Error check failed: '400 Page not found']
05/04/09 11:23:03.959804 zmcontrol[5248].INF [Control server 2/PanasonicIP exiting at 09/05/04 11:23:03]
05/04/09 11:31:38.065531 zmcontrol[5361].INF [Control server 4/PanasonicIP exiting at 09/05/04 11:31:38]
[edit]
Just trying a few things out. I stoped the service, then removed the scripts from the www/zoneminder directory. I then proceeded to restore from the src directory. Then I restarted the service. Unfortunatly it hasn't solved the problem. Everything works fine except cam controls in Montage view.
cordel
Post by cordel »
Check that there are not left over sockets laying about. also try running it from the command line and see what error it throws back at you as it might make a bit more sense.
carlo1973
Post by carlo1973 »
cordel wrote:Check that there are not left over sockets laying about. also try running it from the command line and see what error it throws back at you as it might make a bit more sense.
Okay I stopped the ZM service and purged all .sock files in the /tmp folder. Restarted the ZM service and tested - still no go. In checking the logs I get:
==> zmcontrol.log <==
05/05/09 09:16:53.052833 zmcontrol[16052].FAT [Can't access movePseudoMap member of object of class ZoneMinder::Control::PanasonicIP]
05/05/09 09:16:55.298971 zmcontrol[16054].INF [Starting control server 4/PanasonicIP]
05/05/09 09:16:55.301844 zmcontrol[16055].INF [Control server 4/PanasonicIP starting at 09/05/05 09:16:55]
05/05/09 09:16:56.308264 zmcontrol[16055].FAT [Can't access movePseudoMap member of object of class ZoneMinder::Control::PanasonicIP]
05/05/09 09:19:01.694479 zmcontrol[16086].INF [Starting control server 4/PanasonicIP]
05/05/09 09:19:01.696582 zmcontrol[16087].INF [Control server 4/PanasonicIP starting at 09/05/05 09:19:01]
05/05/09 09:19:02.706572 zmcontrol[16087].FAT [Can't access movePseudoMap member of object of class ZoneMinder::Control::PanasonicIP]
05/05/09 09:19:05.022132 zmcontrol[16088].INF [Starting control server 4/PanasonicIP]
05/05/09 09:19:05.024508 zmcontrol[16089].INF [Control server 4/PanasonicIP starting at 09/05/05 09:19:05]
05/05/09 09:19:06.033451 zmcontrol[16089].FAT [Can't access movePseudoMap member of object of class ZoneMinder::Control::PanasonicIP]
cordel
Post by cordel »
What do you get if you move the camera through the command line?
