KMC7016D and ZoneMinder
watchman
Post by watchman »
I have got a KMC7016D video card like this one http://lionservers.com/kmc7016d/
Does this card work with Zoneminder? I couldn't find any info on this card. This card is dirt cheap and , in my opinion, quite common. So if anyone has brought this card to life with ZoneMinder, would he/she please give me some help.
With Best Regards!
Watchman
kingofkya
Post by kingofkya »
things may have changed but
http://www.zoneminder.com/forums/viewto ... e9329fc1d8
however it may work with the right settings
Edit: Looks like it does work
http://www.zoneminder.com/forums/viewtopic.php?p=19881
watchman
Post by watchman »
Thanks for your reply.
kingofkya wrote:Edit: Looks like it does work
I've tried every option mentioned in the above thread, but still no luck with my KMC7016D.
with
options bttv bttv_debug=1 bttv_gpio=1 bttv_verbose=1 card=77 i2c_hw=1 i2c_scan=1 i2c_udelay=7 tuner=4
I get:
bttv: driver version 0.9.17 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:01:0a.0, irq: 19, latency: 32, mmio: 0xcdfff000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [pre-init]
bttv0: risc main @ 0f4eb000
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: BT878A ARESET
bttv0: i2c scan: found device @ 0x0  [???]
bttv0: i2c scan: found device @ 0x2  [???]
bttv0: i2c scan: found device @ 0x4  [???]
bttv0: i2c scan: found device @ 0x6  [???]
bttv0: i2c scan: found device @ 0x8  [???]
bttv0: i2c scan: found device @ 0xa  [???]
bttv0: i2c scan: found device @ 0xc  [???]
bttv0: i2c scan: found device @ 0xe  [???]
bttv0: i2c scan: found device @ 0x10  [???]
bttv0: i2c scan: found device @ 0x12  [???]
bttv0: i2c scan: found device @ 0x14  [???]
bttv0: i2c scan: found device @ 0x16  [???]
bttv0: i2c scan: found device @ 0x18  [???]
bttv0: i2c scan: found device @ 0x1a  [???]
bttv0: i2c scan: found device @ 0x1c  [lgdt330x]
bttv0: i2c scan: found device @ 0x1e  [???]
bttv0: i2c scan: found device @ 0x20  [???]
bttv0: i2c scan: found device @ 0x22  [???]
bttv0: i2c scan: found device @ 0x24  [???]
bttv0: i2c scan: found device @ 0x26  [???]
bttv0: i2c scan: found device @ 0x28  [???]
bttv0: i2c scan: found device @ 0x2a  [???]
bttv0: i2c scan: found device @ 0x2c  [???]
bttv0: i2c scan: found device @ 0x2e  [???]
bttv0: i2c scan: found device @ 0x30  [IR (hauppauge)]
bttv0: i2c scan: found device @ 0x32  [???]
bttv0: i2c scan: found device @ 0x34  [???]
bttv0: i2c scan: found device @ 0x36  [???]
bttv0: i2c scan: found device @ 0x38  [???]
bttv0: i2c scan: found device @ 0x3a  [???]
bttv0: i2c scan: found device @ 0x3c  [???]
bttv0: i2c scan: found device @ 0x3e  [???]
bttv0: i2c scan: found device @ 0x40  [???]
bttv0: i2c scan: found device @ 0x42  [???]
bttv0: i2c scan: found device @ 0x44  [???]
bttv0: i2c scan: found device @ 0x46  [???]
bttv0: i2c scan: found device @ 0x48  [???]
bttv0: i2c scan: found device @ 0x4a  [???]
bttv0: i2c scan: found device @ 0x4c  [???]
bttv0: i2c scan: found device @ 0x4e  [???]
bttv0: i2c scan: found device @ 0x50  [???]
bttv0: i2c scan: found device @ 0x52  [???]
bttv0: i2c scan: found device @ 0x54  [???]
bttv0: i2c scan: found device @ 0x56  [???]
bttv0: i2c scan: found device @ 0x58  [???]
bttv0: i2c scan: found device @ 0x5a  [???]
bttv0: i2c scan: found device @ 0x5c  [???]
bttv0: i2c scan: found device @ 0x5e  [???]
bttv0: i2c scan: found device @ 0x60  [???]
bttv0: i2c scan: found device @ 0x62  [???]
bttv0: i2c scan: found device @ 0x64  [???]
bttv0: i2c scan: found device @ 0x66  [???]
bttv0: i2c scan: found device @ 0x68  [???]
bttv0: i2c scan: found device @ 0x6a  [???]
bttv0: i2c scan: found device @ 0x6c  [???]
bttv0: i2c scan: found device @ 0x6e  [???]
bttv0: i2c scan: found device @ 0x70  [???]
bttv0: i2c scan: found device @ 0x72  [???]
bttv0: i2c scan: found device @ 0x74  [???]
bttv0: i2c scan: found device @ 0x76  [???]
bttv0: i2c scan: found device @ 0x78  [???]
bttv0: i2c scan: found device @ 0x7a  [???]
bttv0: i2c scan: found device @ 0x7c  [???]
bttv0: i2c scan: found device @ 0x7e  [???]
bttv0: i2c scan: found device @ 0x80  [msp34xx]
bttv0: i2c scan: found device @ 0x82  [???]
bttv0: i2c scan: found device @ 0x84  [???]
bttv0: i2c scan: found device @ 0x86  [tda9887]
bttv0: i2c scan: found device @ 0x88  [???]
bttv0: i2c scan: found device @ 0x8a  [???]
bttv0: i2c scan: found device @ 0x8c  [???]
bttv0: i2c scan: found device @ 0x8e  [???]
bttv0: i2c scan: found device @ 0x90  [???]
bttv0: i2c scan: found device @ 0x92  [???]
bttv0: i2c scan: found device @ 0x94  [???]
bttv0: i2c scan: found device @ 0x96  [???]
bttv0: i2c scan: found device @ 0x98  [???]
bttv0: i2c scan: found device @ 0x9a  [???]
bttv0: i2c scan: found device @ 0x9c  [???]
bttv0: i2c scan: found device @ 0x9e  [???]
bttv0: i2c scan: found device @ 0xa0  [eeprom]
bttv0: i2c scan: found device @ 0xa2  [???]
bttv0: i2c scan: found device @ 0xa4  [???]
bttv0: i2c scan: found device @ 0xa6  [???]
bttv0: i2c scan: found device @ 0xa8  [???]
bttv0: i2c scan: found device @ 0xaa  [???]
bttv0: i2c scan: found device @ 0xac  [???]
bttv0: i2c scan: found device @ 0xae  [???]
bttv0: i2c scan: found device @ 0xb0  [???]
bttv0: i2c scan: found device @ 0xb2  [???]
bttv0: i2c scan: found device @ 0xb4  [???]
bttv0: i2c scan: found device @ 0xb6  [???]
bttv0: i2c scan: found device @ 0xb8  [???]
bttv0: i2c scan: found device @ 0xba  [???]
bttv0: i2c scan: found device @ 0xbc  [???]
bttv0: i2c scan: found device @ 0xbe  [???]
bttv0: i2c scan: found device @ 0xc0  [tuner (analog)]
bttv0: i2c scan: found device @ 0xc2  [tuner (analog)]
bttv0: i2c scan: found device @ 0xc4  [???]
bttv0: i2c scan: found device @ 0xc6  [???]
bttv0: i2c scan: found device @ 0xc8  [???]
bttv0: i2c scan: found device @ 0xca  [???]
bttv0: i2c scan: found device @ 0xcc  [???]
bttv0: i2c scan: found device @ 0xce  [???]
bttv0: i2c scan: found device @ 0xd0  [???]
bttv0: i2c scan: found device @ 0xd2  [???]
bttv0: i2c scan: found device @ 0xd4  [???]
bttv0: i2c scan: found device @ 0xd6  [???]
bttv0: i2c scan: found device @ 0xd8  [???]
bttv0: i2c scan: found device @ 0xda  [???]
bttv0: i2c scan: found device @ 0xdc  [???]
bttv0: i2c scan: found device @ 0xde  [???]
bttv0: i2c scan: found device @ 0xe0  [???]
bttv0: i2c scan: found device @ 0xe2  [???]
bttv0: i2c scan: found device @ 0xe4  [???]
bttv0: i2c scan: found device @ 0xe6  [???]
bttv0: i2c scan: found device @ 0xe8  [???]
bttv0: i2c scan: found device @ 0xea  [???]
bttv0: i2c scan: found device @ 0xec  [???]
bttv0: i2c scan: found device @ 0xee  [???]
bttv0: i2c scan: found device @ 0xf0  [???]
bttv0: i2c scan: found device @ 0xf2  [???]
bttv0: i2c scan: found device @ 0xf4  [???]
bttv0: i2c scan: found device @ 0xf6  [???]
bttv0: i2c scan: found device @ 0xf8  [???]
bttv0: i2c scan: found device @ 0xfa  [???]
bttv0: i2c scan: found device @ 0xfc  [???]
bttv0: i2c scan: found device @ 0xfe  [???]
bttv0: tuner absent
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [audio: mute]
bttv0: video mux: input=0 mux=2
bttv0: PLL: 28636363 => 35468950 .<7>bttv: open minor=0
 ok
bttv: open minor=224
bttv0: open called (type=vbi-cap)
bttv0: PLL: no change required
Any help would be greatly appreciated. Thank you in advance.
kingofkya
Post by kingofkya »
what version of v4l are you running and what version of zoneminder
if you don't know what os ubuntu fedora etc..
ludri
Post by ludri »
I didn't get this card to work (or even on Windows to function properly). After week of trying I gave it back to seller and got kodicom 4400r clone.
watchman
Post by watchman »
Thank you for your reply.
kingofkya wrote:what version of v4l are you running and what version of zoneminder.
ZoneMinder: Release 1.24.1 23rd February 2009
Video for Linux: 3.95
Should I use v4l or v4l2?
kingofkya wrote: if you don't know what os ubuntu fedora etc..
I'm running openSuSE 11.1 64-bit SMP with kernel version 2.6.26.2
watchman
Post by watchman »
ludri wrote:I didn't get this card to work (or even on Windows to function properly). After week of trying I gave it back to seller and got kodicom 4400r clone.
If I send the card back, it would cost me as much as card itself. I think the card has everything in place and its features are too good to be thrown away. If bttv does not work with the card, I would write a new one. But if bttv works with KMC7016D and it was just a matter of right settings, I just would waste my time.
