Page 1 of 1
works with firefox but I am not able to work with zoneminder
Posted: Thu May 07, 2009 7:42 am
by sercik
Hi!
i have a network camera that works with activex *internet explorer, but also with firefox and google browser, (when i connect to ipaddress:port i can choose a server push mode that works with firefox).
When i use firefox with that camera i have done right click and properties on video and i have found this address: 192.168.1.11/videostream.cgi
If i give this address to vlc it is able to play live video with some delay and if i put this address in firefox directly i obtain a static image that refresh every time i refresh browser so i think there are good possibility to make this camera working with zoneminder.
This camera is cheap nightvision and outdoor so could be a great possibility if it is possible to make it working under zoneminder.
Please contact me if you need some information...
this is the devide ID 00051DE8501D
the camera is: http://cgi.ebay.it/TELECAMERA-WIRELESS- ... 1|294%3A50
Posted: Thu May 07, 2009 9:35 am
by sercik
HI i need to add something
i have create in camera a user without password and login with administrator power
now i can access to camera without typing a login and a password
theni have tried to open in firefox 192.168.1.11:1025/videostream.cgi and i have discovered that video stream works but only after some times and that this operation cause firefox to be heavy loaded (firefox uses 50% cpu)
and fps are few than if i access with the standard interfaces in push mode
Posted: Thu May 07, 2009 10:47 pm
by kingofkya
it may work or it may not some cameras produce no standard mjpeg videos if you can make it open to the inet some of is here can see for you
Posted: Fri May 08, 2009 8:52 am
by sercik
do you mean to give you ipaddress of camera?
Posted: Fri May 08, 2009 3:55 pm
by coke
Yes, a publicly accessible address, if you can temporarily throw it on the public-facing side of your router. Or setup NAT to whichever ports it's using, at least 80.
Posted: Fri May 08, 2009 4:08 pm
by sercik
ok i will do that!
but for now i can't...
I will call you when i'm ready with camera.
Goodbye and thanks
camera works
Posted: Wed Jun 24, 2009 5:19 pm
by sercik
Hey camera works!
I'm very happy you can access camera at
sercik.homelinux.com:3502/videostream.cgi?user=admin&pwd=gurreri
this is the manual:
ftp://sohonas.com.tw/pub/User%27smanual ... Manual.pdf
and this is cgi programming guide:
ftp://sohonas.com.tw/pub/M-JPEG/C1002_C ... gGuide.pdf
thank you very much for zoneminder
