The cameras did not record again when they DOWN and they UP
Posted: Sat May 09, 2009 3:09 pm
When the camera is recording function and falls for some reason. then when she rose again no records.
Configuration Camera:
General->
Source Type: Remote
Function: Record
Enabled: yes
Source->
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Path: /axis-cgi/mjpg/video.cgi?resolution=320x240&compression=50&req_fps=2&text=0&date=0&clock=0
Buffers->
Image Buffer Size: 20
Warmup Frames: 25
Pre event image count: 10
Post event image count: 10
Stream Replay Image Buffer: 1000
Alarm Frame Count: 1
When the camera UP can see again but do not correctly recorded.
Error Log:
May 8 23:59:55 debian zmc_m224[11640]: INF [Debug Level = 0, Debug Log = <none>]
May 9 00:00:11 debian zmc_m224[11640]: INF [Starting Capture]
May 9 00:00:12 debian zma_m224[2942]: INF [0042-SP: 80619 - Closing event 42305, section end]
May 9 00:00:12 debian zma_m224[2942]: INF [0042-SP: 80619 - Opening new event 42329, section start]
May 9 00:03:58 debian zma_m224[2942]: INF [0042-SP: 81000 - Processing at 1.61 fps]
May 9 00:08:59 debian zmdc[29762]: INF [Starting pending process, zmc -m 224]
May 9 00:08:59 debian zmdc[11702]: INF ['zmc -m 224' started at 09/05/09 00:08:59]
May 9 00:08:59 debian zmdc[29762]: INF ['zmc -m 224' starting at 09/05/09 00:08:59, pid = 11702]
May 9 00:08:59 debian zmc_m224[11702]: INF [Debug Level = 0, Debug Log = <none>]
May 9 00:09:04 debian zmc_m224[11702]: INF [Starting Capture]
May 9 00:09:24 debian zmdc[29762]: INF [Starting pending process, zmc -m 224]
May 9 00:09:24 debian zmdc[29762]: INF ['zmc -m 224' starting at 09/05/09 00:09:24, pid = 11714]
May 9 00:09:24 debian zmdc[11714]: INF ['zmc -m 224' started at 09/05/09 00:09:24]
May 9 00:09:24 debian zmc_m224[11714]: INF [Debug Level = 0, Debug Log = <none>]
May 9 00:09:39 debian zmc_m224[11714]: INF [Starting Capture]
May 9 00:10:00 debian zma_m224[2942]: INF [0042-SP: 81531 - Closing event 42329, section end]
May 9 00:10:00 debian zma_m224[2942]: INF [0042-SP: 81531 - Opening new event 42341, section start]
May 9 00:12:58 debian zmdc[29762]: INF [Starting pending process, zmc -m 224]
May 9 00:12:58 debian zmdc[29762]: INF ['zmc -m 224' starting at 09/05/09 00:12:58, pid = 11734]
May 9 00:12:58 debian zmdc[11734]: INF ['zmc -m 224' started at 09/05/09 00:12:58]
May 9 00:12:58 debian zmc_m224[11734]: INF [Debug Level = 0, Debug Log = <none>]
May 9 00:13:03 debian zmc_m224[11734]: INF [Starting Capture]
May 9 00:15:29 debian zma_m224[2942]: INF [0042-SP: 82000 - Processing at 1.45 fps]
May 9 00:15:30 debian zmdc[29762]: INF ['zma -m 224' stopping at 09/05/09 00:15:30]
May 9 00:15:30 debian zma_m224[2942]: INF [Got signal 15 (Terminated), exiting]
Some times when restarting Zoneminder the camera record again.
in / tmp / leaves a directory with the format: zmswap-m224
224 is camera ID.
Thanks for your help !!
General->
Source Type: Remote
Function: Record
Enabled: yes
Source->
Buffers->
Warmup Frames: 25
Error Log:
224 is camera ID.
