Remote path for zavio ip camera
fjsobrado
Post by fjsobrado »
I have problems to configure a ip camera (Zavio D611E). My problems is that I don't know the value of variable 'Remote Host Path' in the source tab.
Thanks.
mitch
Post by mitch »
I looked at the manual it supports RTSP and MJPEG but doesn't go into details on their path, so they should work but I don't have the details. If you post the camera info here someone may try to help further.
curtishall
Re: Remote path for zavio ip camera
Post by curtishall »
fjsobrado wrote:Hello,
Thanks.
For MJPEG it's:
http://cameraip:8070/video.mjpg
Zavio limits MJPEG to 15FPS and you have to disable RTSP in the setup menu before you can use MJPEG:
Setting -> Basic -> Camera -> General
The RTSP port is 554
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
fjsobrado
And for rtsp?
Post by fjsobrado »
Ok, thanks for information, the data for mjpeg runs ok, but what is the remote path for rtsp mode?
