I would like to ask anyone, which one has a better image quality between trendnet ip100 and ip110? they all in the similar price range. I get confused to decide which one to buy.
THANKS SO MUCH.
Trendnet ip100
http://www.trendnet.com/products/prodde ... -N&cat=147
Trendnet ip110
http://www.trendnet.com/products/prodde ... 10&cat=148
Trendnet Camera which one is better?
Judging from the specs on the product pages alone, the differences I see are:
Lens sizes: The TV-IP110 has a smaller lens which means it gives you a more wider view angle.
Minimum Illumination: The TV-IP110 has better low light performance
Hardware: The TV-IP110 has twice the ROM size and twice the RAM size.
From just looking at the cameras the TV-IP100 might be more wall mount friendly.
