Buggy RTSP with Panasonic WV-NF302 ?
belanger
Post by belanger »
In 1.24.1 (I also tried SVN checkout from today), I'm trying to configure a Panasonic WV-NF302 but I just can't get it to work.
From Panasonic support I was told to enable RTSP I need to do the following :
http://ip_addr/cgi-bin/set_rtsp?rtsp_mode=1&rtsp_port=554
Using "vlc" in RTSP mode I get a great image -- but it ain't working in zoneminder.
The monitor camera general configuration is in Remote mode with Maximum FPS of 30 and FPS alarm 30.
The source tab has the following:
Remote protocol : RTSP
Remote Method : RTP/RTSP
Remote Host Name : 192.168.1.27
Remote Host Port : 554
Remote Host Path : MediaInput/mpeg4
Remote Host SubPath : /trackID=
Pixels : 640 x 480 in 24 bit color
Zoneminder's debug output :
zm_debug.log.16144:[rtsp @ 0x6313c30]hello state=0
zm_debug.log.16144:05/16/09 17:51:18.165846 zmc_m9[-1].DB2-zm_remote_camera_rtsp.cpp/112 [Waiting for sources]
zm_debug.log.16144:05/16/09 17:51:18.794822 zmc_m9[-1].DB2-zm_rtsp.cpp/44 [Sending RTSP message: SETUP rtsp://192.168.1.27:554/MediaInput/mpeg4/trackID=1 RTSP/1.0
zm_debug.log.16144:05/16/09 17:51:18.899058 zmc_m9[-1].DB2-zm_rtsp.cpp/70 [Received RTSP response: RTSP/1.0 503 Service Unavailable
zm_debug.log.16144:05/16/09 17:51:18.899118 zmc_m9[-1].ERR-zm_rtsp.cpp/90 [Unexpected response code 503, text is 'Service Unavailable']
zm_debug.log.16144:05/16/09 17:51:23.172760 zmc_m9[-1].FAT-zm_remote_camera_rtsp.cpp/118 [No RTSP sources]
I had it working using openRTSP but I just want to use the RTSP mode included in zoneminder.
Any help is appreciated.
Thank you,
Pierre B.
kylejohnson
Post by kylejohnson »
I don't know anything about these cameras so...
What is the URL that you are using in VLC?
You have your Remote Host Path as "MediaInput/peg4" - did you mean "MediaInput/mpeg4"? That still doesn't look right - I can access my camera in vlc with "rtsp://x.x.x.x:554/live.sdp" the "/live.sdp" being the Remote Host Path. Check your camera's WebUI to see if there is something similar that you should be using.
belanger
Post by belanger »
Yes I did mean "MediaInput/mpeg4" (I edited my post).
In VLC I open the RTSP connection with : ip_addr/MediaInput/mpeg4
Works like a charm.... but not within zoneminder.
I read other people reporting the same issue as I'm having.
Thank you, PB
zoneminder
Site Admin
Post by zoneminder »
Did you try using this address in ZM with ffmpeg directly as a camera type?
Phil
belanger
Post by belanger »
zoneminder wrote:Did you try using this address in ZM with ffmpeg directly as a camera type?
Yes .. I'll PM you with a URL where you can view a snapshot because I can't find how to attach a picture here.
Pierre B.[/url]
