Did a fresh stop, deleted logs, started again, here's the heads.
zmwatch.log
head -10 zmwatch.log
05/21/2009 14:19:07.447539 zmwatch[8315].INF [Watchdog starting]
05/21/2009 14:19:07.447925 zmwatch[8315].INF [Watchdog pausing for 30 seconds]
05/21/2009 14:19:37.516697 zmwatch[8315].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/21/2009 14:19:37.516931 zmwatch[8315].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/21/2009 14:19:37.517076 zmwatch[8315].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
05/21/2009 14:19:37.517167 zmwatch[8315].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
05/21/2009 14:19:37.517306 zmwatch[8315].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
05/21/2009 14:19:37.517395 zmwatch[8315].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
05/21/2009 14:19:37.517532 zmwatch[8315].ERR [Can't get shared memory id '7a6d0004', 4: No such file or directory]
05/21/2009 14:19:37.517622 zmwatch[8315].ERR [Can't get shared memory id '7a6d0004', 4: No such file or directory]
head -10 zmdc.log
05/21/2009 14:19:01.601451 zmdc[8228].INF [Server starting at 09/05/21 14:19:01]
05/21/2009 14:19:05.130926 zmdc[8228].INF ['zmc -m 1' starting at 09/05/21 14:19:05, pid = 8251]
05/21/2009 14:19:05.134843 zmdc[8228].ERR ['zmc -m 1' exited abnormally, exit status 30]
05/21/2009 14:19:05.135130 zmdc[8228].INF [Starting pending process, zmc -m 1]
05/21/2009 14:19:05.149488 zmdc[8228].INF ['zmc -m 1' starting at 09/05/21 14:19:05, pid = 8253]
05/21/2009 14:19:05.177826 zmdc[8228].ERR ['zmc -m 1' exited abnormally, exit status 30]
05/21/2009 14:19:05.231263 zmdc[8228].INF ['zma -m 1' starting at 09/05/21 14:19:05, pid = 8254]
05/21/2009 14:19:05.259272 zmdc[8228].ERR ['zma -m 1' exited abnormally, exit status 30]
05/21/2009 14:19:05.259451 zmdc[8228].INF [Starting pending process, zma -m 1]
05/21/2009 14:19:05.262086 zmdc[8228].INF ['zma -m 1' starting at 09/05/21 14:19:05, pid = 8256]
cat zm_debug.log.08488
05/21/09 14:21:42.037199 zma_m16[8488].INF-zm_debug.c/292 [New Debug Level = 4, New Debug Log = /tmp/zm_debug.log.08488]
05/21/09 14:21:42.037507 zma_m16[8488].ERR-zm_monitor.cpp/2253 [Can't run query: Unknown column 'Protocol' in 'field list']
Where did I go wrong, and how can I fix it?
Checked the setup on the cameras, it switched from my previous Axis presets to RTSP's, tried to reset one from a preset and got this:
grep DB408B *
error.log:[Thu May 21 14:28:32 2009] [error] [client 127.0.0.1] SQL-ERROR(DB408B): select Type, Device, Channel, Format, Protocol, Method, Host, Port, Path, SubPath, Width, Height, Palette, MaxFPS, Controllable, ControlId, ControlDevice, ControlAddress, DefaultRate, DefaultScale from MonitorPresets where Id = '13', referer: http://127.0.0.1/index.php?view=monitorpreset&mid=1
error.log:[Thu May 21 14:28:32 2009] [error] [client 127.0.0.1] SQL-ERROR(DB408B): Unknown column 'Protocol' in 'field list', referer: http://127.0.0.1/index.php?view=monitorpreset&mid=1
