gian@recorder:~$ sudo dpkg -i --force-depends zoneminder_1.24.1-pre-1_amd64.deb
Selecting previously deselected package zoneminder.
(Reading database ... 27082 files and directories currently installed.)
Unpacking zoneminder (from zoneminder_1.24.1-pre-1_amd64.deb) ...
Setting up zoneminder (1.24.1-pre-1) ...
Installing new version of config file /etc/zm/zm.conf ...
Starting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) fail ed: Unknown database 'zm' at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/Zon eMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
failure
invoke-rc.d: initscript zoneminder, action "start" failed.
dpkg: error processing zoneminder (--install):
subprocess post-installation script returned error exit status 255
Processing triggers for man-db ...
Errors were encountered while processing:
zoneminder
gian@recorder:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Starting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Unknown database 'zm' at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
failure
dpkg: error processing zoneminder (--configure):
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
gian@recorder:~$
I trashed a working 1.23 thinking that moving to 1.24 with a .deb would have been easy.... what should I do now?
thanks for your time,
-Gian
Ubuntu Jaunty install failed with .deb file...
You might find help in the thread about the Zoneminder 1.24.1 deb package:
http://www.zoneminder.com/forums/viewtopic.php?t=13555
If you don't have any previous Zoneminder data, I would just delete the older zoneminder packages you've installed with the -purge option and try reinstalling.
