exit status 255
exit status 255
i not see the fps and see black screen in zoneminder console but i see good in kopete software,i have kubuntu 9.04 please help me
May 26 21:35:37 ubuntu zmc_dvideo[10626]: ERR [Failed to open video device /dev/video: No such file or directory]
May 26 21:35:37 ubuntu zmdc[9927]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
May 26 21:35:47 ubuntu zmwatch[9956]: ERR [Can't get shared memory id '7a6d000c', 12: Nessun file o directory]
May 26 21:35:47 ubuntu zmwatch[9956]: INF [Restarting capture daemon for New, shared memory not valid]
May 26 21:35:48 ubuntu zmdc[10628]: INF ['zmc -d /dev/video' started at 09/05/26 21:35:48]
May 26 21:35:48 ubuntu zmdc[9927]: INF ['zmc -d /dev/video' starting at 09/05/26 21:35:48, pid = 10628]
May 26 21:35:48 ubuntu zmwatch[9956]: INF ['zmc -d /dev/video' starting at 09/05/26 21:35:48, pid = 10628]
May 26 21:35:48 ubuntu zmc_dvideo[10628]: INF [Debug Level = 0, Debug Log = <none>]
May 26 21:35:48 ubuntu zmc_dvideo[10628]: ERR [Failed to open video device /dev/video: No such file or directory]
May 26 21:35:48 ubuntu zmdc[9927]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
try this
Hi , first try to do : chmod 777 /dev/video*
then let know.
J.
then let know.
J.
i try also this but no work help!!!!
£10 that it's rights.
1. Post the output from this command into this thread :
Quote:
cat /var/log/syslog | tail
2. Try :
Quote:
chmod 777 /dev/video0
Quote:
/etc/init.d/zoneminder restart
3. Or try this :
Quote:
adduder www-data video
4. And maybe this :
Quote:
zmfix
5. Could even be memory, shmget :
Quote:
echo 134217728 >/proc/sys/kernel/shmmax
btw, 2 and 5 won't survive a reboot.
2. Try :
3. Or try this :
4. And maybe this :
Quote:
zmfix
Your log shows "No such file or directory" , if you do ls -l /dev/vid* ... do you actually see a file named "/dev/video" and in another post you write you did "chmod 777 /dev/video0". Is it your configuration that isn't pointing to the right place? You probably need to include the number of the video device in your PATH.mascimax wrote:sorry i wrong to post i have zoneminder 1.23.3
Pierre B.
Yezzz, i don't know why but i change the path to /tmp/myfile.txt and now works, first step ok! but i don't want to create a txt i want to do an action:
system("echo 'Hello I am testing the Alarm' | gnokii --sendsms 474548754");
In normal condition when i put this command in my console i receive an SMS.
But when i put it in /usr/bin/zmfilter.pl i don't receive SMS.
So interesting ...
J.
So interesting ...
J.
Any users can create files in /tmp that belongs to them, if you come from Windows world just remember you can't write and do anything you want anywhere unless you are "root" or have the rights to do it -- and by default, normal privileges don't allow you to do anything you would want.johnnytolengo wrote:Yezzz, i don't know why but i change the path to /tmp/myfile.txt and now works.
I know nothing about gnokii but I would try to put the full path in zmfilter.pl (/usr/local/bin/...) perhaps that will help.
I so....... ST....... yes thing was that my device USB for the phone had lower permisions
Just i fix it chmod 777 ttyUSB, now its working .
The last thing i am looking for is :
how can i detect if a camera has status ON? (in perl)
I want to create a SMS warming when some camera stops working.
thank you all for share your knowledges with me.
Regards.
J.
Regards.
J.
Well if you unplug the camera I think the image will become all "blue" (or black?) , not sure if zoneminder will log this type or "error" but this could be useful to detect broken cameras and/or capture cards.johnnytolengo wrote: how can i detect if a camera has status ON? (in perl)
ps: so you have a phone connected on a USB port and you use the phone to send a SMS, correct? What type of phone are you using for this?
i am using a nokia 6020 plus cable CA-42 (its usb), software i use simply gnokii you can download form gnokii.org.
but it just enoght to do apt-get install gnokii
then create a file in /etc/gnokii with this input
to confirm you are working type:
gnokii --identify
and for send an SMS
If you find how to check if a camera is OFF please let my know, i think it will be a new super feature for ZM.
J.
[global]
port = /dev/ttyUSB0
model = 6020
initlength = default
connection = dku5
use_locking = yes
smsc_timeout = 10
gnokii --identify
and for send an SMS
echo 'Criminals had arrive to home, we are enjoying here' | gnokii --sendsms 454741547
J.
tanks for your reply,belanger wrote:Your log shows "No such file or directory" , if you do ls -l /dev/vid* ... do you actually see a file named "/dev/video" and in another post you write you did "chmod 777 /dev/video0". Is it your configuration that isn't pointing to the right place? You probably need to include the number of the video device in your PATH.mascimax wrote:sorry i wrong to post i have zoneminder 1.23.3
Pierre B.
1) in witch way i include the number of the video device in my PATH??
2) in witch way i see if my configuration that isn't pointing to the right place?
this ia are my ls -l /dev/vid*
root@ubuntu:~# ls -l /dev/video0
crw-rw---- 1 root video 81, 0 2009-05-27 21:33 /dev/video0
root@ubuntu:~# ls -l /dev/video1
crw-rw---- 1 root video 81, 2 2009-05-27 21:33 /dev/video1
root@ubuntu:~# ls -l /dev/video2
crw-rw---- 1 root video 81, 4 2009-05-27 21:33 /dev/video2
root@ubuntu:~# ls -l /dev/video3
crw-rw---- 1 root video 81, 6 2009-05-27 21:33 /dev/video3
root@ubuntu:~#
tanks
I strongly suggest you first read the documentation :mascimax wrote: tanks for your reply,
tanks
http://www.zoneminder.com/wiki/index.php/Documentation
Added or not the "number" of the video device is also described in the documentation. Changes are that you add it within the PATH to your device, for example /dev/video0 , /dev/video1 , etc and this might depend on the type of capture card you use. If you use a USB camera, I can't help you because I don't have experience with those.
Pierre B.
i have pci capture card with 4 input
root@ubuntu:~# zmu -d /dev/video0 -q -v
Video Capabilities
Type: 45
Can capture
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 1
Audio Channels: 0
Maximum Width: 720
Maximum Height: 578
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 0
Height: 0
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 35090
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
root@ubuntu:~#
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Video Capabilities
Type: 45
Can capture
Does teletext
Can clip
Video Channels: 1
Audio Channels: 0
Maximum Width: 720
Maximum Height: 578
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 0
Height: 0
Picture Attributes
Colour Depth: 24
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 35090
Whiteness: 0
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
root@ubuntu:~#
