Extremely low FPS on version 1.24.1
nombrandue
Post by nombrandue »
I am working on a CentOS 5.2 system that is running a PV-183 CCTV card from BlueCherry, which is showing increased oddities over the old 4 port single chip BT878 card (4 ports spanned across one chip) which shows the monitor, Cycle and montage FPS as going from 20FPS to showing this: State: Idle - -3736.22 fps. That is a negative 3736 FPS (appears that the image stream freezes until one sees the FPS statement) and I have seen this through both cards, even with one camera set up on this. During this time I am seeing this in the logs:
May 27 21:58:14 minazuki zmc_dvideo1[3825]: INF [Front_Door: 15000 - Capturing at 30.30 fps]
May 27 21:58:32 minazuki zmc_dvideo2[3833]: INF [Living_room: 3000 - Capturing at 6.02 fps]
May 27 21:58:34 minazuki zma_m1[3829]: INF [Front_Door: 2000 - Processing at 3.92 fps]
May 27 21:58:47 minazuki zmc_dvideo1[3825]: INF [Front_Door: 16000 - Capturing at 30.30 fps]
May 27 21:58:58 minazuki zmc_dvideo3[3837]: INF [Office: 4000 - Capturing at 7.81 fps]
May 27 21:59:21 minazuki zmc_dvideo1[3825]: INF [Front_Door: 17000 - Capturing at 29.41 fps]
May 27 21:59:54 minazuki zmc_dvideo1[3825]: INF [Front_Door: 18000 - Capturing at 30.30 fps]
May 27 22:00:27 minazuki zmc_dvideo1[3825]: INF [Front_Door: 19000 - Capturing at 30.30 fps]
May 27 22:01:01 minazuki zmc_dvideo1[3825]: INF [Front_Door: 20000 - Capturing at 29.41 fps]
May 27 22:01:06 minazuki zmc_dvideo3[3837]: INF [Office: 5000 - Capturing at 7.81 fps]
May 27 22:01:18 minazuki zmc_dvideo2[3833]: INF [Living_room: 4000 - Capturing at 6.02 fps]
May 27 22:01:20 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 7, image 20567, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:01:20 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 13, image 20573, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:01:34 minazuki zmc_dvideo1[3825]: INF [Front_Door: 21000 - Capturing at 30.30 fps]
May 27 22:02:08 minazuki zmc_dvideo1[3825]: INF [Front_Door: 22000 - Capturing at 29.41 fps]
May 27 22:02:41 minazuki zmc_dvideo1[3825]: INF [Front_Door: 23000 - Capturing at 30.30 fps]
May 27 22:02:49 minazuki zma_m1[3829]: INF [Front_Door: 3000 - Processing at 3.92 fps]
May 27 22:03:14 minazuki zmc_dvideo1[3825]: INF [Front_Door: 24000 - Capturing at 30.30 fps]
May 27 22:03:18 minazuki zmc_dvideo3[3837]: INF [Office: 6000 - Capturing at 7.58 fps]
May 27 22:03:48 minazuki zmc_dvideo1[3825]: INF [Front_Door: 25000 - Capturing at 29.41 fps]
May 27 22:03:49 minazuki zms[3917]: INF [Debug Level = 0, Debug Log = <none>]
May 27 22:03:49 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 77, image 25037, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:03:49 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 3, image 25043, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:03:52 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 23, image 25143, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:03:54 minazuki zms[3919]: INF [Debug Level = 0, Debug Log = <none>]
May 27 22:03:54 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 3, image 25203, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:03:57 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 3, image 25283, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:04:01 minazuki zmc_dvideo1[3825]: WAR [Buffer overrun at index 3, image 25363, slow down capture, speed up analysis or increase ring buffer size]
May 27 22:04:01 minazuki zmc_dvideo1[3825]: WAR [Last image read from shared memory 7 seconds ago, zma may have gone away]
May 27 22:04:04 minazuki zmwatch[3860]: INF [Restarting analysis daemon for Front_Door, time since last analysis 10 seconds (1243479844-1243479834)]
May 27 22:04:09 minazuki zms[3923]: INF [Debug Level = 0, Debug Log = <none>]
May 27 22:04:09 minazuki zmdc[3802]: INF ['zma -m 1' stopping at 09/05/27 22:04:09]
May 27 22:04:10 minazuki zma_m1[3829]: INF [Got signal 15 (Terminated), exiting]
May 27 22:04:10 minazuki zmdc[3802]: INF ['zma -m 1' exited normally]
May 27 22:04:10 minazuki zmwatch[3860]: INF ['zma -m 1' stopping at 09/05/27 22:04:09]
May 27 22:04:10 minazuki zmdc[3802]: INF [Starting pending process, zma -m 1]
May 27 22:04:10 minazuki zmdc[3802]: INF ['zma -m 1' starting at 09/05/27 22:04:10, pid = 3925]
May 27 22:04:10 minazuki zmdc[3925]: INF ['zma -m 1' started at 09/05/27 22:04:10]
May 27 22:04:10 minazuki zma_m1[3925]: INF [Debug Level = 0, Debug Log = <none>]
May 27 22:04:10 minazuki zma_m1[3925]: INF [In mode 3/1, warming up]
May 27 22:04:14 minazuki zms[3919]: INF [Got signal 15 (Terminated), exiting]
May 27 22:04:17 minazuki zmc_dvideo2[3833]: INF [Living_room: 5000 - Capturing at 5.59 fps]
May 27 22:04:25 minazuki zms[3923]: INF [Got signal 15 (Terminated), exiting]
May 27 22:04:37 minazuki zms[3929]: INF [Debug Level = 0, Debug Log = <none>]
May 27 22:04:48 minazuki zms[3917]: INF [Got signal 15 (Terminated), exiting]
May 27 22:04:52 minazuki zms[3929]: INF [Got signal 15 (Terminated), exiting]
May 27 22:05:15 minazuki zmc_dvideo1[3825]: INF [Front_Door: 26000 - Capturing at 11.49 fps]
May 27 22:05:23 minazuki zmc_dvideo3[3837]: INF [Office: 7000 - Capturing at 8.00 fps]
May 27 22:05:28 minazuki zmaudit[3846]: INF [Filesystem event '1/13417' does not exist in database]
May 27 22:05:28 minazuki zmaudit[3846]: INF [deleting]
May 27 22:05:28 minazuki zmaudit[3846]: INF [Filesystem event '1/13418' does not exist in database]
May 27 22:05:59 minazuki zma_m1[3925]: INF [Front_Door: 1000 - Processing at 9.17 fps]
May 27 22:06:21 minazuki zmc_dvideo2[3833]: INF [Living_room: 6000 - Capturing at 8.06 fps]
May 27 22:06:26 minazuki zms[3948]: INF [Debug Level = 0, Debug Log = <none>]
May 27 22:06:48 minazuki zmc_dvideo3[3837]: INF [Office: 8000 - Capturing at 11.76 fps]
May 27 22:06:53 minazuki zmc_dvideo1[3825]: INF [Front_Door: 27000 - Capturing at 10.20 fps]
May 27 22:07:36 minazuki zma_m1[3925]: INF [Front_Door: 2000 - Processing at 10.31 fps]
May 27 22:08:10 minazuki zmc_dvideo3[3837]: INF [Office: 9000 - Capturing at 12.20 fps]
May 27 22:08:11 minazuki zmc_dvideo2[3833]: INF [Living_room: 7000 - Capturing at 9.09 fps]
May 27 22:08:28 minazuki zmc_dvideo1[3825]: INF [Front_Door: 28000 - Capturing at 10.53 fps]
May 27 22:09:10 minazuki zma_m1[3925]: INF [Front_Door: 3000 - Processing at 10.64 fps]
May 27 22:09:32 minazuki zmc_dvideo3[3837]: INF [Office: 10000 - Capturing at 12.20 fps]
May 27 22:10:00 minazuki zmc_dvideo2[3833]: INF [Living_room: 8000 - Capturing at 9.26 fps]
May 27 22:10:02 minazuki zmc_dvideo1[3825]: INF [Front_Door: 29000 - Capturing at 10.64 fps]
May 27 22:10:27 minazuki zms[3948]: INF [Got signal 15 (Terminated), exiting]
May 27 22:10:44 minazuki zma_m1[3925]: INF [Front_Door: 4000 - Processing at 10.64 fps]
May 27 22:10:54 minazuki zmc_dvideo3[3837]: INF [Office: 11000 - Capturing at 12.20 fps]
May 27 22:11:37 minazuki zmc_dvideo1[3825]: INF [Front_Door: 30000 - Capturing at 10.53 fps]
I see the "WAR [Buffer overrun at" errors and am working on those (Newer card, different settings and other insanity like that) but as this frames per second issue has been going on since I upgraded to 1.24.1 built from source) and will get most of the other warnings cleaned up.
As a quick side note, using Video For Linux 2, what would be the best setting for US NTSC cards? I have played with a lot of the settings but can't get it right, and it is causing lines to appear on any motion.
