Zavio F312A Wireless IP Camera
Posted: Fri May 29, 2009 7:34 am
got couple of those, overally I am pleased with the extreme low price and picture quality way better than the others at same pirice tag (linksys, trendnet...).
Camera is able to stream both Mpeg4SP and MJPEG simultaneously, but that only if RTSP is disabled (with RTSP enabled its only Mpeg4). Cameras own motion detection works very well, only downside is that it does'nt send clear tcp trigger events (http, smtp, ftp only, had to write simple perl script to warp http event trigger on server to zmtrigger.pl, did not want to change any original files). Has all the ftp, bonjour, smtp upload etc. that also can be sheduled.
to connect to stream first you have to set port in camera config, then you are ready.
RTSP enabled
Source Type: ffmpeg
Source Path: rtsp://cameraip:8554/video.mp4
rtsp://cameraip:554/video.3gp
RTSP disabled
Source Type: ffmpeg
Source Path: http://cameraip:8090/video.mp4
http://cameraip:8070/video.mjpg
RTSP enabled
Source Type: ffmpeg
RTSP disabled
Source Type: ffmpeg
