I can not configure my Acti camera with zonemider 1.24
califalla
Post by califalla »
Can you post or paste a picture o display how to configure the acti camera. I already tried with the Acti preset but it does not work. it only turns the ip adress in the zoneminder main display it turns green. However when I try to display it, it does not show any image.
This is what I am doing:
Source:
Remote Protocol: RTSP
Remote Host Name: Admin:123456@192.168.1.50
Remote Host Port: 7070
Remote Host Path:
Remote Host SubPath: /track
Capture Width (pixels): 640
Capture Height (pixels) : 480
Preserve Aspect Ratio
Orientation: Normal
General:
Source Type: Remote
Function: Modect
Enabled: X
Linked Monitors: acti
Maximum FPS: 15
Alarm Maximum FPS: 15
Reference Image Blend %ge: 7
Triggers None available
Zoneminder console:
1 Monitor
Options
Configured for Low Bandwidth
Name Function Source Events Hour Day Week Month Archived Zones Order Mark
0 0 0 0 0 0 1
acti Modect 192.168.1.50
henriquejf
Post by henriquejf »
i think that should be an easy one:
provide me with the link you use to access your acti cam directly from the browser, not within zm, than i will give you what you need; (mask the link before sending, of course)
actually, what i want to say is that you left the "Remote Host Path" blank, and i think that is the problem; i think it should read something like "/axis-cgi/mjpg/video.cgi?resolution" there (of course not that exactly because thats for some axis cams)
maybe you have just inverted the "path" and "subpath" fields;
EDIT: also your "Remote Host Name: Admin:123456@192.168.1.50" seems to me to be wrong to me; try just the ip there; maybe the preset you used is not right by default....
good luck
Henrique Barbosa
Consultant
Juiz de Fora, MG - Brazil
califalla
Still can not see the video
Post by califalla »
Hi, I still can not see the video or image. Do you know the cgi for Acti or where can I find it. My acti camera is ACM1231.
Thank You
Carlos E. Falla
henriquejf
i dont know the path for your camera;
as i said, if you give me the path you use to watch its streams, for example: "192.0.0.0/axis-cgi/mjpg/video.cgi?resolution" i think i can give you the zm configuration;
Henrique Barbosa
Consultant
coke
Post by coke »
I've got an ACM-5611 that's working without authorization. I unchecked "enable RTSP authentication" on the camera's own setup page, and used the ZM preset. There may be better settings, but these are working for me right now. Also, make sure the resolution in ZM is the same as the resolution set on your ACTi, and lose the user:password in your address if you disable RTSP Authen.
My video settings on the ACTi Web Configurator are:
Streaming method: RTP Over UDP
RTSP Authen Enable (not checked)
RTP B2 Frame Enable (checked)
Audio in: disabled
Resolution: 1280x1024
Frame Rate Mode: constant
Frame Rate: 8
Encoder Type: MPEG4
Video Bitrate Mode: Variable Bit Rate
Video Quality: High
Serial Port Baud Rate: 9600
Serial Port Control: 8,N,1
RTSP Port: 7070
Video Control Port: 6001
califalla
Coke what streaming Path are you using?
Post by califalla »
Both thank you for all the info. Coke what streaming path are you using to see your acti camera?
Thank You,
Carlos E. Falla
neek
Post by neek »
I'm also struggling with the exact same problem. I have my camera configured for MPEG4 and unchecked the check for authentication.
I can use VLC to connect to it at rtsp://192.168.xxx:7070
I can not find any way to get ZM 1.24.1 to see an image or capture events at that port.
I've also configured VLC per this thread: http://www.zoneminder.com/forums/viewtopic.php?t=13718
and then try to connect to that stream as a remote stream, and it still doesn't work.
I've tried this on a FreeBSD box with 1.23.3, and a Fedora 10 and ubuntu 8.04 server box with 1.24.1.
Does anyone have any ideas how to further debug this?
thanks so much.
coke
Post by coke »
/track, the one the preset picked for me.
Edit: No, actually, that's the subpath the preset picked. Path is blank.
viperdak
acti config
Post by viperdak »
having the exact same problem. Running Ubuntu server 9.04 with ZM version 1.24.2.
Have some ACTi cameras model 5601 set up just as described in this post and this post:http://www.zoneminder.com/forums/viewto ... light=acti.
One thing the preset did not do was set a remote host path. Does anyone know the path for ACTi cams? Maybe this is the problem. Everything works fine through VLC by using rtsp://<ip>:7070.
Also on the main ZM screen the function and source are both yellow.
here is the tail from /var/log
Sep 11 09:37:21 uam-crossett2 zmc_m1[5269]: WAR [Unable to get picture from fram        e]
Sep 11 09:37:22 uam-crossett2 zmc_m1[5269]: WAR [Unable to get picture from fram        e]
Sep 11 09:37:22 uam-crossett2 zms[5294]: INF [Debug Level = 0, Debug Log = <none>]
edit: here is what i am getting now
 Sep 11 10:42:12 uam-crossett2 zms[8426]: INF [Authenticated user 'lando']
Sep 11 10:42:12 uam-crossett2 zmc_m1[8404]: WAR [Unable to get picture from frame]
Sep 11 10:42:43 uam-crossett2 last message repeated 221 times
Sep 11 10:43:44 uam-crossett2 last message repeated 419 times
Sep 11 10:44:45 uam-crossett2 last message repeated 420 times
any help would be greatly appreciated! i feel like it's just aaaaallmost ready to work
viperdak
Post by viperdak »
update
partial success!?
here is what i'm getting now:
root@uam-crossett2:~# tail /var/log/messages
Sep 11 12:18:33 uam-crossett2 zmfilter[6418]: INF [Scanning for events]
Sep 11 12:18:33 uam-crossett2 zmdc[6393]: INF ['zmwatch.pl' starting at 09/09/11 12:18:33, pid = 6422]
Sep 11 12:18:33 uam-crossett2 zmdc[6422]: INF ['zmwatch.pl' started at 09/09/11 12:18:33]
Sep 11 12:18:33 uam-crossett2 zmwatch[6422]: INF [Watchdog starting]
Sep 11 12:18:33 uam-crossett2 zmwatch[6422]: INF [Watchdog pausing for 30 seconds]
Sep 11 12:18:33 uam-crossett2 zmdc[6393]: INF ['zmupdate.pl -c' starting at 09/09/11 12:18:33, pid = 6424]
Sep 11 12:18:33 uam-crossett2 zmdc[6424]: INF ['zmupdate.pl -c' started at 09/09/11 12:18:33]
Sep 11 12:18:52 uam-crossett2 zms[6437]: INF [Debug Level = 0, Debug Log = <none>]
Sep 11 12:18:52 uam-crossett2 zms[6437]: INF [Authenticated user 'lando']
Sep 11 12:19:10 uam-crossett2 zmc_m1[6415]: INF [Monitor-1: 1000 - Capturing at 26.32 fps]
Now the issue i'm dealing with is i'm not getting an image/video stream when i open the monitor. Just a blank area where the video should be. (Firefox) With the monitor window open it says at the bottom state: Idle - 30.79 fps (the numbers varying in realtime so i know that part is working at least).
Under the row of play,pause, etc buttons it says Mode:Live Zoom 1.0x.
Just for kicks i tried it also in Internet Exploder with the same result.
Am i missing some silly config somewhere? i'm scared to mess with it anymore now that i've got some fps kickin.
Everything under options/images is default except i have cambozola.jar checked.
Thanks in advance! so close now..
viperdak
Post by viperdak »
update to the update =)
everything is working swimmingly except for the streaming part. I guess the camera path doesn't matter because there wasn't one loaded on the preset and it doesn't appear to matter.
It records perfectly and the stills look great. I just need to figure out how to view a stream of the video/frames. I'm assuming this might have something to do with ffmpeg? If anyone has knowledge of that beast feel free to chime in.
Sorry for all of the posts, maybe all this will help someone in the future.
Thanks in advance!
Landon
