Page 1 of 1
how it works.. new filter.
Posted: Sat Feb 21, 2004 12:13 am
by fernando
i was testing the new filter options.. how i set the to filter multiple cameras ID. the use of 2,3 like in Restricted Camera Ids dont work...
btw: when i ser Restricted Camera Ids those are the only monitor that user can view.. have to be admited camera ids or something like that.
Re: how it works.. new filter.
Posted: Sat Feb 21, 2004 10:16 am
by zoneminder
Hi Fernando,
To match multiple monitors in a filter do 'MonitorId' + 'in set' + '2,3' which will match only events from those monitors. I don't think I completely understand your last point but if you are saying that users who are configured to only be able to view certain monitors should not be allow to see events from other ones using this method then that is how it should work.
Phil,
