No error no image!!
No error no image!!
hello,
I'm trying to set up 2 ip cams with zoneminder 1.24.1 and OpenSuse 11.1 64 bit.
My ip cams are DCS-900 and Edimax IC1500.
I can see image from the cameras with Mozilla Firefox at:
http:/192.198.1.4/video.cgi (for the DCS-900)
http://192.168.1.5/snapshot.cgi (for the Edimax IC 1500)
I see no error (after a lot of effort) at the logs:
zmdc.log:
06/09/09 16:37:10.579479 zmdc[6512].INF ['zmc -m 1' starting at 09/06/09 16:37:10, pid = 6535]
06/09/09 16:37:10.695911 zmdc[6512].INF ['zmc -m 2' starting at 09/06/09 16:37:10, pid = 6539]
06/09/09 16:37:10.812882 zmdc[6512].INF ['zmfilter.pl' starting at 09/06/09 16:37:10, pid = 6543]
06/09/09 16:37:10.935491 zmdc[6512].INF ['zmaudit.pl -c' starting at 09/06/09 16:37:10, pid = 6547]
06/09/09 16:37:11.083168 zmdc[6512].INF ['zmwatch.pl' starting at 09/06/09 16:37:11, pid = 6551]
06/09/09 16:37:11.219240 zmdc[6512].INF ['zmupdate.pl -c' starting at 09/06/09 16:37:11, pid = 6557]
zmwatch.log:
06/09/09 16:37:11.208964 zmwatch[6551].INF [Watchdog starting]
06/09/09 16:37:11.209521 zmwatch[6551].INF [Watchdog pausing for 30 seconds]
un 9 16:37:07 linux-4l5d zmdc[6512]: INF [Server starting at 09/06/09 16:37:07]
Jun 9 16:37:10 linux-4l5d zmdc[6512]: INF ['zmc -m 1' starting at 09/06/09 16:37:10, pid = 6535]
Jun 9 16:37:10 linux-4l5d zmdc[6535]: INF ['zmc -m 1' started at 09/06/09 16:37:10]
Jun 9 16:37:10 linux-4l5d zmc_m1[6535]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 16:37:10 linux-4l5d zmc_m1[6535]: INF [Starting Capture]
Jun 9 16:37:10 linux-4l5d zmdc[6512]: INF ['zmc -m 2' starting at 09/06/09 16:37:10, pid = 6539]
Jun 9 16:37:10 linux-4l5d zmdc[6539]: INF ['zmc -m 2' started at 09/06/09 16:37:10]
Jun 9 16:37:10 linux-4l5d zmc_m2[6539]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 16:37:10 linux-4l5d zmc_m2[6539]: INF [Starting Capture]
Jun 9 16:37:10 linux-4l5d zmdc[6512]: INF ['zmfilter.pl' starting at 09/06/09 16:37:10, pid = 6543]
Jun 9 16:37:10 linux-4l5d zmdc[6543]: INF ['zmfilter.pl' started at 09/06/09 16:37:10]
Jun 9 16:37:10 linux-4l5d zmdc[6547]: INF ['zmaudit.pl -c' started at 09/06/09 16:37:10]
Jun 9 16:37:10 linux-4l5d zmdc[6512]: INF ['zmaudit.pl -c' starting at 09/06/09 16:37:10, pid = 6547]
Jun 9 16:37:11 linux-4l5d zmdc[6551]: INF ['zmwatch.pl' started at 09/06/09 16:37:11]
Jun 9 16:37:11 linux-4l5d zmdc[6512]: INF ['zmwatch.pl' starting at 09/06/09 16:37:11, pid = 6551]
Jun 9 16:37:11 linux-4l5d zmfilter[6543]: INF [Scanning for events]
Jun 9 16:37:11 linux-4l5d zmwatch[6551]: INF [Watchdog starting]
Jun 9 16:37:11 linux-4l5d zmwatch[6551]: INF [Watchdog pausing for 30 seconds]
Jun 9 16:37:11 linux-4l5d zmdc[6512]: INF ['zmupdate.pl -c' starting at 09/06/09 16:37:11, pid = 6557]
Jun 9 16:37:11 linux-4l5d zmdc[6557]: INF ['zmupdate.pl -c' started at 09/06/09 16:37:11]
Jun 9 16:37:17 linux-4l5d zms[6571]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 16:37:19 linux-4l5d zms[6575]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 16:37:30 linux-4l5d zms[6584]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 16:37:30 linux-4l5d zms[6583]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 16:47:17 linux-4l5d zms[6571]: INF [Got signal 15 (Terminated), exiting]
Jun 9 16:47:19 linux-4l5d zms[6575]: INF [Got signal 15 (Terminated), exiting]
Jun 9 16:47:30 linux-4l5d zms[6584]: INF [Got signal 15 (Terminated), exiting]
Jun 9 16:47:30 linux-4l5d zms[6583]: INF [Got signal 15 (Terminated), exiting]
What is the problem and I see no image but a cursor turning around all the time?
any ideas?
At the settings I have put width 180 heigth 140, otherwise I do not see the cadre at all (even without picture)
At sysctl I have set the kernel.shmmax = 536848892
and kernel.shmall = 536848892
ANd of course I have seen most of the forum infos!
Thank you for your help !
zmdc.log:
zmwatch.log:
any ideas?
06/09/09 21:39:17.935617 zms[-1].INF-zm_debug.c/292 [New Debug Level = 3, New Debug Log = /var/log/zm/zm_debug.log.05515]
06/09/09 21:39:17.936119 zms[-1].DB1-zms.cpp/92 [Query: mode=jpeg&monitor=2&scale=100&maxfps=15&connkey=295425&rand=1244572757]
06/09/09 21:39:17.936446 zms[-1].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
06/09/09 21:39:17.936596 zms[-1].DB1-zm_monitor.cpp/338 [monitor purpose=0]
06/09/09 21:39:17.936606 zms[-1].DB1-zm_monitor.cpp/345 [mem.size=3025524]
06/09/09 21:39:17.936657 zms[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
06/09/09 21:39:17.936975 zms[-1].DB1-zm_monitor.cpp/458 [Monitor reception has function 2]
06/09/09 21:39:17.936984 zms[-1].DB1-zm_monitor.cpp/459 [Monitor reception LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
06/09/09 21:39:17.936992 zms[-1].DB1-zm_monitor.cpp/460 [Monitor reception IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
06/09/09 21:39:17.937004 zms[-1].DB1-zm_monitor.cpp/2457 [Loaded monitor 2(reception), 0 zones]
06/09/09 21:39:17.937069 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/09/09 21:39:17.937089 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/09/09 21:39:20.437265 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/09/09 21:39:20.437325 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/09/09 21:39:20.437336 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1244572760.437, Z:100, E:1 F:0]
06/09/09 21:39:20.437392 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/09/09 21:39:20.437403 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/09/09 21:39:23.941750 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/09/09 21:39:23.941813 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/09/09 21:39:23.941825 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1244572763.942, Z:100, E:1 F:0]
06/09/09 21:39:23.941871 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/09/09 21:39:23.941882 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/09/09 21:39:27.443399 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/09/09 21:39:27.443463 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/09/09 21:39:27.443475 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1244572767.443, Z:100, E:1 F:0]
06/09/09 21:39:27.443537 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/09/09 21:39:27.443548 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/10/09 07:53:50.782464 zmc_m1[-1].INF-zm_debug.c/292 [New Debug Level = 3, New Debug Log = /var/log/zm/zm_debug.log.04697]
06/10/09 07:53:50.783558 zmc_m1[-1].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
06/10/09 07:53:50.783719 zmc_m1[-1].DB2-zm_remote_camera_http.cpp/68 [Request: GET /video.cgi HTTP/1.1
User-Agent: ZoneMinder/1.24.1
Host: 192.168.1.4
Connection: Keep-Alive
06/10/09 07:53:50.783785 zmc_m1[-1].DB1-zm_monitor.cpp/338 [monitor purpose=1]
06/10/09 07:53:50.783794 zmc_m1[-1].DB1-zm_monitor.cpp/345 [mem.size=1009524]
06/10/09 07:53:50.784675 zmc_m1[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
06/10/09 07:53:50.785302 zmc_m1[-1].DB1-zm_monitor.cpp/458 [Monitor eisodos has function 2]
06/10/09 07:53:50.785316 zmc_m1[-1].DB1-zm_monitor.cpp/459 [Monitor eisodos LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
06/10/09 07:53:50.785324 zmc_m1[-1].DB1-zm_monitor.cpp/460 [Monitor eisodos IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
06/10/09 07:53:50.785801 zmc_m1[-1].DB1-zm_zone.cpp/889 [Got 1 zones for monitor eisodos]
06/10/09 07:53:50.785820 zmc_m1[-1].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 179,0 179,139 0,139']
06/10/09 07:53:50.785830 zmc_m1[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
06/10/09 07:53:50.785838 zmc_m1[-1].DB3-zm_zone.cpp/796 [Got coordinate 179,0 from polygon string]
06/10/09 07:53:50.785846 zmc_m1[-1].DB3-zm_zone.cpp/796 [Got coordinate 179,139 from polygon string]
06/10/09 07:53:50.785853 zmc_m1[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,139 from polygon string]
06/10/09 07:53:50.785863 zmc_m1[-1].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
06/10/09 07:53:50.785872 zmc_m1[-1].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:756, MxAP:18900, FB:3x3, MnFP:756, MxFP:18900, MnBS:504, MxBS:0, MnB:1, MxB:0, OF: 0]
06/10/09 07:53:50.786204 zmc_m1[-1].DB1-zm_monitor.cpp/2457 [Loaded monitor 1(eisodos), 1 zones]
06/10/09 07:53:50.786217 zmc_m1[-1].INF-zmc.cpp/186 [Starting Capture]
06/10/09 07:53:50.789434 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/104 [Connected to host, socket = 3]
06/10/09 07:53:50.789481 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/125 [Request sent]
06/10/09 07:53:51.188353 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 200 bytes]
06/10/09 07:53:51.188413 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/195 [Read 200 bytes]
06/10/09 07:53:51.188500 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/266 [Got status '200' (OK), http version 1.0]
06/10/09 07:53:51.188533 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/289 [Got content type 'multipart/x-mixed-replace'
06/10/09 07:53:51.188542 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/293 [Got content boundary '--video boundary--']
06/10/09 07:53:51.188561 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/386 [Unable to extract subheader from stream, retrying]
06/10/09 07:53:51.344283 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 1460 bytes]
06/10/09 07:53:51.344345 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/195 [Read 1460 bytes]
06/10/09 07:53:51.344370 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/386 [Unable to extract subheader from stream, retrying]
06/10/09 07:53:51.349656 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 1460 bytes]
06/10/09 07:53:51.349695 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/195 [Read 1460 bytes]
06/10/09 07:53:51.349718 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/386 [Unable to extract subheader from stream, retrying]
06/10/09 07:53:51.350877 zmc_m1[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 1460 bytes]
The last 2 lines repeat many times.....
Host: 192.168.1.4
06/10/09 07:53:50.885848 zmc_m2[-1].INF-zm_debug.c/292 [New Debug Level = 3, New Debug Log = /var/log/zm/zm_debug.log.04701]
06/10/09 07:53:50.886353 zmc_m2[-1].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
06/10/09 07:53:50.886496 zmc_m2[-1].DB2-zm_remote_camera_http.cpp/68 [Request: GET /snapshot.cgi HTTP/1.1
Host: 192.168.1.5
Authorization: Basic YWRtaW46MTIzNA==
06/10/09 07:53:50.886619 zmc_m2[-1].DB1-zm_monitor.cpp/338 [monitor purpose=1]
06/10/09 07:53:50.886629 zmc_m2[-1].DB1-zm_monitor.cpp/345 [mem.size=3025524]
06/10/09 07:53:50.890356 zmc_m2[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
06/10/09 07:53:50.890719 zmc_m2[-1].DB1-zm_monitor.cpp/458 [Monitor reception has function 2]
06/10/09 07:53:50.890729 zmc_m2[-1].DB1-zm_monitor.cpp/459 [Monitor reception LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
06/10/09 07:53:50.890737 zmc_m2[-1].DB1-zm_monitor.cpp/460 [Monitor reception IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
06/10/09 07:53:50.891112 zmc_m2[-1].DB1-zm_zone.cpp/889 [Got 1 zones for monitor reception]
06/10/09 07:53:50.891130 zmc_m2[-1].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 179,0 179,139 0,139']
06/10/09 07:53:50.891139 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
06/10/09 07:53:50.891148 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 179,0 from polygon string]
06/10/09 07:53:50.891155 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 179,139 from polygon string]
06/10/09 07:53:50.891163 zmc_m2[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,139 from polygon string]
06/10/09 07:53:50.891172 zmc_m2[-1].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
06/10/09 07:53:50.891180 zmc_m2[-1].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:756, MxAP:18900, FB:3x3, MnFP:756, MxFP:18900, MnBS:504, MxBS:0, MnB:1, MxB:0, OF: 0]
06/10/09 07:53:50.891511 zmc_m2[-1].DB1-zm_monitor.cpp/2457 [Loaded monitor 2(reception), 1 zones]
06/10/09 07:53:50.891525 zmc_m2[-1].INF-zmc.cpp/186 [Starting Capture]
06/10/09 07:53:50.894707 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/104 [Connected to host, socket = 3]
06/10/09 07:53:50.894754 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/125 [Request sent]
06/10/09 07:53:50.912704 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 17 bytes]
06/10/09 07:53:50.912752 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/195 [Read 17 bytes]
06/10/09 07:53:50.912771 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/774 [Unable to extract entire header from stream, continuing]
06/10/09 07:53:50.914705 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 40 bytes]
06/10/09 07:53:50.914720 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/195 [Read 40 bytes]
06/10/09 07:53:50.914812 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/774 [Unable to extract entire header from stream, continuing]
06/10/09 07:53:50.915087 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 25 bytes]
06/10/09 07:53:50.915105 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/195 [Read 25 bytes]
06/10/09 07:53:50.915115 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/774 [Unable to extract entire header from stream, continuing]
06/10/09 07:53:50.944816 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 80 bytes]
06/10/09 07:53:50.944900 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/195 [Read 80 bytes]
06/10/09 07:53:50.944922 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/685 [Got status '200' (OK), http version 1.1]
06/10/09 07:53:50.944932 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/707 [Got content type 'multipart/x-mixed-replace']
06/10/09 07:53:50.944940 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/716 [Got content boundary '--"myboundary"']
06/10/09 07:53:50.944950 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/884 [Unable to extract subheader from stream, retrying]
06/10/09 07:53:50.967195 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 26 bytes]
06/10/09 07:53:50.967241 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/195 [Read 26 bytes]
06/10/09 07:53:50.967304 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/884 [Unable to extract subheader from stream, retrying]
06/10/09 07:53:50.968415 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 24 bytes]
06/10/09 07:53:50.968439 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/195 [Read 24 bytes]
06/10/09 07:53:50.968453 zmc_m2[-1].DB3-zm_remote_camera_http.cpp/884 [Unable to extract subheader from stream, retrying]
Host: 192.168.1.5
06/15/09 16:38:52.863059 �[-1].DB3-zm_remote_camera_http.cpp/884 [Unable to extract subheader from stream, retrying]
06/15/09 16:38:52.864247 �[-1].DB3-zm_remote_camera_http.cpp/170 [Expecting 1448 bytes]
06/15/09 16:38:52.864284 �[-1].DB3-zm_remote_camera_http.cpp/195 [Read 1448 bytes]
06/15/09 16:38:52.864304 �[-1].DB3-zm_remote_camera_http.cpp/884 [Unable to extract subheader from stream, retrying]
06/15/09 16:38:52.864512 �[-1].DB3-zm_remote_camera_h*** glibc detected *** /usr/local/bin/zmc: munmap_chunk(): invalid pointer: 0x00000000060d8cd0 ***
======= Backtrace: =========
/lib64/libc.so.6[0x7f78c01d0118]
/lib64/libc.so.6[0x7f78c01ef5c5]
/lib64/libc.so.6[0x7f78c01ef7c7]
/usr/local/bin/zmc[0x40eb03]
/usr/local/bin/zmc[0x43140d]
/usr/local/bin/zmc[0x432513]
/usr/local/bin/zmc[0x424876]
/usr/local/bin/zmc[0x406afa]
/lib64/libc.so.6(__libc_start_main+0xe6)[0x7f78c017a586]
/usr/local/bin/zmc[0x406459]
======= Memory map: ========
00400000-00467000 r-xp 00000000 08:02 1176714 /usr/local/bin/zmc
00666000-00667000 r--p 00066000 08:02 1176714 /usr/local/bin/zmc
00667000-00671000 rw-p 00067000 08:02 1176714 /usr/local/bin/zmc
00671000-06152000 rw-p 00671000 00:00 0 [heap]
7f78bbf2c000-7f78bc20f000 rw-s 00000000 00:0a 458755 /SYSV7a6d0002 (deleted)
7f78bc20f000-7f78bc214000 r-xp 00000000 08:02 1176865 /usr/local/lib/libogg.so.0.5.3
7f78bc214000-7f78bc413000 ---p 00005000 08:02 1176865 /usr/local/lib/libogg.so.0.5.3
7f78bc413000-7f78bc414000 r--p 00004000 08:02 1176865 /usr/local/lib/libogg.so.0.5.3
7f78bc414000-7f78bc415000 rw-p 00005000 08:02 1176865 /usr/local/lib/libogg.so.0.5.3
7f78bc415000-7f78bc41d000 r-xp 00000000 08:02 1224124 /lib64/librt-2.9.so
7f78bc41d000-7f78bc61c000 ---p 00008000 08:02 1224124 /lib64/librt-2.9.so
7f78bc61c000-7f78bc61d000 r--p 00007000 08:02 1224124 /lib64/librt-2.9.so
7f78bc61d000-7f78bc61e000 rw-p 00008000 08:02 1224124 /lib64/librt-2.9.so
7f78bc61e000-7f78bc68d000 r-xp 00000000 08:02 1208579 /usr/lib64/liboil-0.3.so.0.3.0
7f78bc68d000-7f78bc88c000 ---p 0006f000 08:02 1208579 /usr/lib64/liboil-0.3.so.0.3.0
7f78bc88c000-7f78bc88d000 r--p 0006e000 08:02 1208579 /usr/lib64/liboil-0.3.so.0.3.0
7f78bc88d000-7f78bc8a7000 rw-p 0006f000 08:02 1208579 /usr/lib64/liboil-0.3.so.0.3.0
7f78bc8a7000-7f78bc8aa000 rw-p 7f78bc8a7000 00:00 0
7f78bc8aa000-7f78bc951000 r-xp 00000000 08:02 1208394 /usr/lib64/libmp4v2.so.0.0.0
7f78bc951000-7f78bcb50000 ---p 000a7000 08:02 1208394 /usr/lib64/libmp4v2.so.0.0.0
7f78bcb50000-7f78bcb55000 r--p 000a6000 08:02 1208394 /usr/lib64/libmp4v2.so.0.0.0
7f78bcb55000-7f78bcb57000 rw-p 000ab000 08:02 1208394 /usr/lib64/libmp4v2.so.0.0.0
7f78bcb57000-7f78bccad000 r-xp 00000000 08:02 1208143 /usr/lib64/libcrypto.so.0.9.8
7f78bccad000-7f78bcead000 ---p 00156000 08:02 1208143 /usr/lib64/libcrypto.so.0.9.8
7f78bcead000-7f78bceba000 r--p 00156000 08:02 1208143 /usr/lib64/libcrypto.so.0.9.8
7f78bceba000-7f78bced1000 rw-p 00163000 08:02 1208143 /usr/lib64/libcrypto.so.0.9.8
7f78bced1000-7f78bced4000 rw-p 7f78bced1000 00:00 0
7f78bced4000-7f78bcf1b000 r-xp 00000000 08:02 1209650 /usr/lib64/libssl.so.0.9.8
7f78bcf1b000-7f78bd11a000 ---p 00047000 08:02 1209650 /usr/lib64/libssl.so.0.9.8
7f78bd11a000-7f78bd11c000 r--p 00046000 08:02 1209650 /usr/lib64/libssl.so.0.9.8
7f78bd11c000-7f78bd122000 rw-p 00048000 08:02 1209650 /usr/lib64/libssl.so.0.9.8
7f78bd122000-7f78bd137000 r-xp 00000000 08:02 1223009 /lib64/libnsl-2.9.so
7f78bd137000-7f78bd336000 ---p 00015000 08:02 1223009 /lib64/libnsl-2.9.so
7f78bd336000-7f78bd337000 r--p 00014000 08:02 1223009 /lib64/libnsl-2.9.so
7f78bd337000-7f78bd338000 rw-p 00015000 08:02 1223009 /lib64/libnsl-2.9.so
7f78bd338000-7f78bd33a000 rw-p 7f78bd338000 00:00 0
7f78bd33a000-7f78bd347000 r-xp 00000000 08:02 1224102 /lib64/libcrypt-2.9.so
7f78bd347000-7f78bd547000 ---p 0000d000 08:02 1224102 /lib64/libcrypt-2.9.so
7f78bd547000-7f78bd548000 r--p 0000d000 08:02 1224102 /lib64/libcrypt-2.9.so
7f78bd548000-7f78bd549000 rw-p 0000e000 08:02 1224102 /lib64/libcrypt-2.9.so
7f78bd549000-7f78bd577000 rw-p 7f78bd549000 00:00 0
7f78bd577000-7f78bd57a000 r-xp 00000000 08:02 1223102 /lib64/libgpg-error.so.0.4.0
7f78bd57a000-7f78bd779000 ---p 00003000 08:02 1223102 /lib64/libgpg-error.so.0.4.0
7f78bd779000-7f78bd77a000 r--p 00002000 08:02 1223102 /lib64/libgpg-error.so.0.4.0
7f78bd77a000-7f78bd77b000 rw-p 00003000 08:02 1223102 /lib64/libgpg-error.so.0.4.0
7f78bd77b000-7f78bd7e0000 r-xp 00000000 08:02 1223112 /lib64/libgcrypt.so.11.4.4
7f78bd7e0000-7f78bd9df000 ---p 00065000 08:02 1223112 /lib64/libgcrypt.so.11.4.4
7f78bd9df000-7f78bd9e0000 r--p 00064000 08:02 1223112 /lib64/libgcrypt.so.11.4.4
7f78bd9e0000-7f78bd9e2000 rw-p 00065000 08:02 1223112 /lib64/libgcrypt.so.11.4.4
7f78bd9e2000-7f78bda8f000 r-xp 00000000 08:02 1208716 /usr/lib64/libgnutls.so.26.4.5
7f78bda8f000-7f78bdc8f000 ---p 000ad000 08:02 1208716 /usr/lib64/libgnutls.so.26.4.5
7f78bdc8f000-7f78bdc98000 r--p 000ad000 08:02 1208716 /usr/lib64/libgnutls.so.26.4.5
7f78bdc98000-7f78bdc9a000 rw-p 000b6000 08:02 1208716 /usr/lib64/libgnutls.so.26.4.5
7f78bdc9a000-7f78bdd32000 r-xp 00000000 08:02 1208593 /usr/lib64/libxvidcore.so.4.2
7f78bdd32000-7f78bdf32000 ---p 00098000 08:02 1208593 /usr/lib64/libxvidcore.so.4.2
7f78bdf32000-7f78bdf33000 r--p 00098000 08:02 1208593 /usr/lib64/libxvidcore.so.4.2
7f78bdf33000-7f78bdf3d000 rw-p 00099000 08:02 1208593 /usr/lib64/libxvidcore.so.4.2
7f78bdf3d000-7f78bdfa7000 rw-p 7f78bdf3d000 00:00 0
7f78bdfa7000-7f78be033000 r-xp 00000000 08:02 1209335 /usr/lib64/libx264.so.67
7f78be033000-7f78be232000 ---p 0008c000 08:02 1209335 /usr/lib64/libx264.so.67
7f78be232000-7f78be234000 r--p 0008b000 08:02 1209335 /usr/lib64/libx264.so.67
7f78be234000-7f78be235000 rw-p 0008d000 08:02 1209335 /usr/lib64/libx264.so.67
7f78be235000-7f78be23a000 rw-p 7f78be235000 00:00 0
7f78be23a000-7f78be25d000 r-xp 00000000 08:02 1176851 /usr/local/lib/libvorbis.so.0.3.1
7f78be25d000-7f78be45c000 ---p 00023000 08:02 1176851 /usr/local/lib/libvorbis.so.0.3.1
7f78be45c000-7f78be45d000 r--p 00022000 08:02 1176851 /usr/local/lib/libvorbis.so.0.3.1
7f78be45d000-7f78be46b000 rw-p 00023000 08:02 1176851 /usr/local/lib/libvorbis.so.0.3.1
7f78be46b000-7f78be487000 r-xp 00000000 08:02 1176860 /usr/local/lib/libvorbisenc.so.2.0.2
7f78be487000-7f78be686000 ---p 0001c000 08:02 1176860 /usr/local/lib/libvorbisenc.so.2.0.2
7f78be686000-7f78be687000 r--p 0001b000 08:02 1176860 /usr/local/lib/libvorbisenc.so.2.0.2
7f78be687000-7f78be846000 rw-p 0001c000 08:02 1176860 /usr/local/lib/libvorbisenc.so.2.0.2
7f78be846000-7f78be84b000 rw-p 7f78be846000 00:00 0
7f78be84b000-7f78be898000 r-xp 00000000 08:02 312852 /usr/lib64/libtheora.so.0.3.4
7f78be898000-7f78bea98000 ---p 0004d000 08:02 312852 /usr/lib64/libtheora.so.0.3.4
7f78bea98000-7f78bea99000 r--p 0004d000 08:02 312852 /usr/lib64/libtheora.so.0.3.4
7f78bea99000-7f78bea9a000 rw-p 0004e000 08:02 312852 /usr/lib64/libtheora.so.0.3.4
7f78bea9a000-7f78beab2000 r-xp 00000000 08:02 1208421 /usr/lib64/libspeex.so.1.5.0
7f78beab2000-7f78becb2000 ---p 00018000 08:02 1208421 /usr/lib64/libspeex.so.1.5.0
7f78becb2000-7f78becb3000 r--p 00018000 08:02 1208421 /usr/lib64/libspeex.so.1.5.0
7f78becb3000-7f78becb4000 rw-p 00019000 08:02 1208421 /usr/lib64/libspeex.so.1.5.0
7f78becb4000-7f78bed3d000 r-xp 00000000 08:02 312895 /usr/lib64/libschroedinger-1.0.so.0.1.0
7f78bed3d000-7f78bef3d000 ---p 00089000 08:02 312895 /usr/lib64/libschroedinger-1.0.so.0.1.0
7f78bef3d000-7f78bef3e000 r--p 00089000 08:02 312895 /usr/lib64/libschroedinger-1.0.so.0.1.0
7f78bef3e000-7f78bef40000 rw-p 0008a000 08:02 312895 /usr/lib64/libschroedinger-1.0.so.0.1.0
7f78bef40000-7f78bef41000 rw-p 7f78bef40000 00:00 0
7f78bef41000-7f78befb3000 r-xp 00000000 08:02 1176844 /usr/local/lib/libmp3lame.so.0.0.0
7f78befb3000-7f78bf1b3000 ---p 00072000 08:02 1176844 /usr/local/lib/libmp3lame.so.0.0.0
7f78bf1b3000-7f78bf1b4000 r--p 00072000 08:02 1176844 /usr/local/lib/libmp3lame.so.0.0.0
7f78bf1b4000-7f78bf1b5000 rw-p 00073000 08:02 1176844 /usr/local/lib/libmp3lame.so.0.0.0
7f78bf1b5000-7f78bf1e6000 rw-p 7f78bf1b5000 00:00 0
7f78bf1e6000-7f78bf1f1000 r-xp 00000000 08:02 1208293 /usr/lib64/libgsm.so.1.0.12
7f78bf1f1000-7f78bf3f0000 ---p 0000b000 08:02 1208293 /usr/lib64/libgsm.so.1.0.12
7f78bf3f0000-7f78bf3f1000 r--p 0000a000 08:02 1208293 /usr/lib64/libgsm.so.1.0.12
7f78bf3f1000-7f78bf3f2000 rw-p 0000b000 08:02 1208293 /usr/lib64/libgsm.so.1.0.12
7f78bf3f2000-7f78bf431000 r-xp 00000000 08:02 1208530 /usr/lib64/libfaad.so.2.0.0
7f78bf431000-7f78bf630000 ---p 0003f000 08:02 1208530 /usr/lib64/libfaad.so.2.0.0
7f78bf630000-7f78bf631000 r--p 0003e000 08:02 1208530 /usr/lib64/libfaad.so.2.0.0
7f78bf631000-7f78bf634000 rw-p 0003f000 08:02 1208530 /usr/lib64/libfaad.so.2.0.0
7f78bf634000-7f78bf643000 r-xp 00000000 08:02 312138 /usr/lib64/libfaac.so.0.0.0
7f78bf643000-7f78bf842000 ---p 0000f000 08:02 312138 /usr/lib64/libfaac.so.0.0.0
7f78bf842000-7f78bf843000 r--p 0000e000 08:02 312138 /usr/lib64/libfaac.so.0.0.0
7f78bf843000-7f78bf846000 rw-p 0000f000 08:02 312138 /usr/lib64/libfaac.so.0.0.0
7f78bf846000-7f78bf873000 r-xp 00000000 08:02 1209015 /usr/lib64/libamrwb.so.3.0.0
7f78bf873000-7f78bfa72000 ---p 0002d000 08:02 1209015 /usr/lib64/libamrwb.so.3.0.0
7f78bfa72000-7f78bfa73000 r--p 0002c000 08:02 1209015 /usr/lib64/libamrwb.so.3.0.0
7f78bfa73000-7f78bfa74000 rw-p 0002d000 08:02 1209015 /usr/lib64/libamrwb.so.3.0.0
7f78bfa74000-7f78bfa75000 rw-p 7f78bfa74000 00:00 0
7f78bfa75000-7f78bfab0000 r-xp 00000000 08:02 312128 /usr/lib64/libamrnb.so.3.0.0
7f78bfab0000-7f78bfcaf000 ---p 0003b000 08:02 312128 /usr/lib64/libamrnb.so.3.0.0
7f78bfcaf000-7f78bfcb0000 r--p 0003a000 08:02 312128 /usr/lib64/libamrnb.so.3.0.0
7f78bfcb0000-7f78bfcb3000 rw-p 0003b000 08:02 312128 /usr/lib64/libamrnb.so.3.0.0
7f78bfcb3000-7f78bfcb4000 rw-p 7f78bfcb3000 00:00 0
7f78bfcb4000-7f78bfcc2000 r-xp 00000000 08:02 1223034 /lib64/libbz2.so.1.0.5
7f78bfcc2000-7f78bfec1000 ---p 0000e000 08:02 1223034 /lib64/libbz2.so.1.0.5
7f78bfec1000-7f78bfec2000 r--p 0000d000 08:02 1223034 /lib64/libbz2.so.1.0.5
7f78bfec2000-7f78bfec3000 rw-p 0000e000 08:02 1223034 /lib64/libbz2.so.1.0.5
7f78bfec3000-7f78bff56000 r-xp 00000000 08:02 1208904 /usr/lib64/libdirac_encoder.so.0.1.0
7f78bff56000-7f78c0156000 ---p 00093000 08:02 1208904 /usr/lib64/libdirac_encoder.so.0.1.0
7f78c0156000-7f78c0159000 r--p 00093000 08:02 1208904 /usr/lib64/libdirac_encoder.so.0.1.0
7f78c0159000-7f78c015b000 rw-p 00096000 08:02 1208904 /usr/lib64/libdirac_encoder.so.0.1.0
7f78c015b000-7f78c015c000 rw-p 7f78c015b000 00:00 0
7f78c015c000-7f78c02ab000 r-xp 00000000 08:02 1224099 /lib64/libc-2.9.so
7f78c02ab000-7f78c04ab000 ---p 0014f000 08:02 1224099 /lib64/libc-2.9.so
7f78c04ab000-7f78c04af000 r--p 0014f000 08:02 1224099 /lib64/libc-2.9.so
7f78c04af000-7f78c04b0000 rw-p 00153000 08:02 1224099 /lib64/libc-2.9.so
7f78c04b0000-7f78c04b5000 rw-p 7f78c04b0000 00:00 0
7f78c04b5000-7f78c04cb000 r-xp 00000000 08:02 1223103 /lib64/libgcc_s.so.1
7f78c04cb000-7f78c06cb000 ---p 00016000 08:02 1223103 /lib64/libgcc_s.so.1
7f78c06cb000-7f78c06cc000 r--p 00016000 08:02 1223103 /lib64/libgcc_s.so.1
7f78c06cc000-7f78c06cd000 rw-p 00017000 08:02 1223103 /lib64/libgcc_s.so.1
7f78c06cd000-7f78c0722000 r-xp 00000000 08:02 1224106 /lib64/libm-2.9.so
7f78c0722000-7f78c0921000 ---p 00055000 08:02 1224106 /lib64/libm-2.9.so
7f78c0921000-7f78c0922000 r--p 00054000 08:02 1224106 /lib64/libm-2.9.so
7f78c0922000-7f78c0923000 rw-p 00055000 08:02 1224106 /lib64/libm-2.9.so
7f78c0923000-7f78c0a14000 r-xp 00000000 08:02 1208164 /usr/lib64/libstdc++.so.6.0.10
7f78c0a14000-7f78c0c13000 ---p 000f1000 08:02 1208164 /usr/lib64/libstdc++.so.6.0.10
7f78c0c13000-7f78c0c1a000 r--p 000f0000 08:02 1208164 /usr/lib64/libstdc++.so.6.0.10
7f78c0c1a000-7f78c0c1c000 rw-p 000f7000 08:02 1208164 /usr/lib64/libstdc++.so.6.0.10
7f78c0c1c000-7f78c0c2f000 rw-p 7f78c0c1c000 00:00 0
7f78c0c2f000-7f78c0c51000 r-xp 00000000 08:02 1208585 /usr/lib64/libjpeg.so.62.0.0
7f78c0c51000-7f78c0e51000 ---p 00022000 08:02 1208585 /usr/lib64/libjpeg.so.62.0.0
7f78c0e51000-7f78c0e52000 r--p 00022000 08:02 1208585 /usr/lib64/libjpeg.so.62.0.0
7f78c0e52000-7f78c0e53000 rw-p 00023000 08:02 1208585 /usr/lib64/libjpeg.so.62.0.0
7f78c0e53000-7f78c0e68000 r-xp 00000000 08:02 1223025 /lib64/libz.so.1.2.3
7f78c0e68000-7f78c1067000 ---p 00015000 08:02 1223025 /lib64/libz.so.1.2.3
7f78c1067000-7f78c1068000 r--p 00014000 08:02 1223025 /lib64/libz.so.1.2.3
7f78c1068000-7f78c1069000 rw-p 00015000 08:02 1223025 /lib64/libz.so.1.2.3
7f78c1069000-7f78c106b000 r-xp 00000000 08:02 1224104 /lib64/libdl-2.9.so
7f78c106b000-7f78c126b000 ---p 00002000 08:02 1224104 /lib64/libdl-2.9.so
7f78c126b000-7f78c126c000 r--p 00002000 08:02 1224104 /lib64/libdl-2.9.so
7f78c126c000-7f78c126d000 rw-p 00003000 08:02 1224104 /lib64/libdl-2.9.so
7f78c126d000-7f78c1283000 r-xp 00000000 08:02 1223017 /lib64/libpthread-2.9.so
7f78c1283000-7f78c1483000 ---p 00016000 08:02 1223017 /lib64/libpthread-2.9.so
7f78c1483000-7f78c1484000 r--p 00016000 08:02 1223017 /lib64/libpthread-2.9.so
7f78c1484000-7f78c1485000 rw-p 00017000 08:02 1223017 /lib64/libpthread-2.9.so
7f78c1485000-7f78c1489000 rw-p 7f78c1485000 00:00 0
7f78c1489000-7f78c15b0000 r-xp 00000000 08:02 1208272 /usr/lib64/libmysqlclient.so.15.0.0
7f78c15b0000-7f78c17af000 ---p 00127000 08:02 1208272 /usr/lib64/libmysqlclient.so.15.0.0
7f78c17af000-7f78c17b2000 r--p 00126000 08:02 1208272 /usr/lib64/libmysqlclient.so.15.0.0
7f78c17b2000-7f78c17e4000 rw-p 00129000 08:02 1208272 /usr/lib64/libmysqlclient.so.15.0.0
7f78c17e4000-7f78c17e5000 rw-p 7f78c17e4000 00:00 0
7f78c17e5000-7f78c17ff000 r-xp 00000000 08:02 312679 /usr/lib64/libgnutls-openssl.so.26.4.5
7f78c17ff000-7f78c19ff000 ---p 0001a000 08:02 312679 /usr/lib64/libgnutls-openssl.so.26.4.5
7f78c19ff000-7f78c1a00000 r--p 0001a000 08:02 312679 /usr/lib64/libgnutls-openssl.so.26.4.5
7f78c1a00000-7f78c1a01000 rw-p 0001b000 08:02 312679 /usr/lib64/libgnutls-openssl.so.26.4.5
7f78c1a01000-7f78c1a30000 r-xp 00000000 08:02 1208190 /usr/lib64/libpcre.so.0.0.1
7f78c1a30000-7f78c1c2f000 ---p 0002f000 08:02 1208190 /usr/lib64/libpcre.so.0.0.1
7f78c1c2f000-7f78c1c30000 r--p 0002e000 08:02 1208190 /usr/lib64/libpcre.so.0.0.1
7f78c1c30000-7f78c1c31000 rw-p 0002f000 08:02 1208190 /usr/lib64/libpcre.so.0.0.1
7f78c1c31000-7f78c1c3a000 r-xp 00000000 08:02 1209339 /usr/lib64/libavutil.so.49.15.0
7f78c1c3a000-7f78c1e39000 ---p 00009000 08:02 1209339 /usr/lib64/libavutil.so.49.15.0
7f78c1e39000-7f78c1e3a000 r--p 00008000 08:02 1209339 /usr/lib64/libavutil.so.49.15.0
7f78c1e3a000-7f78c1e3b000 rw-p 00009000 08:02 1209339 /usr/lib64/libavutil.so.49.15.0
7f78c1e3b000-7f78c1e3e000 rw-p 7f78c1e3b000 00:00 0
7f78c1e3e000-7f78c2228000 r-xp 00000000 08:02 1209400 /usr/lib64/libavcodec.so.52.20.0
7f78c2228000-7f78c2428000 ---p 003ea000 08:02 1209400 /usr/lib64/libavcodec.so.52.20.0
7f78c2428000-7f78c2432000 r--p 003ea000 08:02 1209400 /usr/lib64/libavcodec.so.52.20.0
7f78c2432000-7f78c2440000 rw-p 003f4000 08:02 1209400 /usr/lib64/libavcodec.so.52.20.0
7f78c2440000-7f78c2750000 rw-p 7f78c2440000 00:00 0
7f78c2750000-7f78c27e1000 r-xp 00000000 08:02 312135 /usr/lib64/libavformat.so.52.31.0
7f78c27e1000-7f78c29e1000 ---p 00091000 08:02 312135 /usr/lib64/libavformat.so.52.31.0
7f78c29e1000-7f78c29e5000 r--p 00091000 08:02 312135 /usr/lib64/libavformat.so.52.31.0
7f78c29e5000-7f78c29ee000 rw-p 00095000 08:02 312135 /usr/lib64/libavformat.so.52.31.0
7f78c29ee000-7f78c2a3a000 rw-p 7f78c29ee000 00:00 0
7f78c2a3a000-7f78c2a63000 r-xp 00000000 08:02 1209385 /usr/lib64/libswscale.so.0.7.1
7f78c2a63000-7f78c2c63000 ---p 00029000 08:02 1209385 /usr/lib64/libswscale.so.0.7.1
7f78c2c63000-7f78c2c64000 r--p 00029000 08:02 1209385 /usr/lib64/libswscale.so.0.7.1
7f78c2c64000-7f78c2c65000 rw-p 0002a000 08:02 1209385 /usr/lib64/libswscale.so.0.7.1
7f78c2c65000-7f78c2c83000 r-xp 00000000 08:02 1224095 /lib64/ld-2.9.so
7f78c2e15000-7f78c2e16000 rw-p 7f78c2e15000 00:00 0
7f78c2e16000-7f78c2e4b000 r--s 00000000 08:02 821505 /var/run/nscd/services
7f78c2e4b000-7f78c2e5d000 rw-p 7f78c2e4b000 00:00 0
7f78c2e80000-7f78c2e82000 rw-p 7f78c2e80000 00:00 0
7f78c2e82000-7f78c2e83000 r--p 0001d000 08:02 1224095 /lib64/ld-2.9.so
7f78c2e83000-7f78c2e84000 rw-p 0001e000 08:02 1224095 /lib64/ld-2.9.so
7fffcae6e000-7fffcae82000 rwxp 7ffffffea000 00:00 0 [stack]
7fffcae82000-7fffcae83000 rw-p 7fffffffe000 00:00 0
7fffcaffe000-7fffcafff000 r-xp 7fffcaffe000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
06/15/09 16:38:52.864565 �[-1].DB3-zm_remote_camera_http.cpp/195 [Read 1448 bytes]
The zm_debug.log.08068 has the following:
06/17/09 16:17:26.641843 zms[-1].INF-zm_debug.c/292 [New Debug Level = 3, New Debug Log = /var/log/zm/zm_debug.log.08068]
06/17/09 16:17:26.642171 zms[-1].DB1-zms.cpp/92 [Query: mode=jpeg&monitor=3&scale=100&maxfps=15&buffer=1000&connkey=577948&rand=1245244646]
06/17/09 16:17:26.642997 zms[-1].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
06/17/09 16:17:26.643283 zms[-1].DB1-zm_monitor.cpp/338 [monitor purpose=0]
06/17/09 16:17:26.643294 zms[-1].DB1-zm_monitor.cpp/345 [mem.size=3025524]
06/17/09 16:17:26.643400 zms[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
06/17/09 16:17:26.643740 zms[-1].DB1-zm_monitor.cpp/458 [Monitor BarB has function 2]
06/17/09 16:17:26.643750 zms[-1].DB1-zm_monitor.cpp/459 [Monitor BarB LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
06/17/09 16:17:26.643757 zms[-1].DB1-zm_monitor.cpp/460 [Monitor BarB IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
06/17/09 16:17:26.643773 zms[-1].DB1-zm_monitor.cpp/2457 [Loaded monitor 3(BarB), 0 zones]
06/17/09 16:17:26.643905 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/17/09 16:17:26.643926 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/17/09 16:17:26.644089 zms[-1].DB2-zm_monitor.cpp/3342 [Checking swap image location]
06/17/09 16:17:26.644100 zms[-1].DB3-zm_monitor.cpp/3343 [Checking swap image path]
06/17/09 16:17:26.644143 zms[-1].DB3-zm_monitor.cpp/2866 [Swap path '/tmp/zmswap-m3/zmswap-q577948' missing, creating]
06/17/09 16:17:26.644205 zms[-1].DB2-zm_monitor.cpp/3364 [Assigning temporary buffer]
06/17/09 16:17:26.651510 zms[-1].DB2-zm_monitor.cpp/3367 [Assigned temporary buffer]
06/17/09 16:17:27.651736 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/17/09 16:17:27.651786 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/17/09 16:17:27.651798 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1245244647.652, Z:100, E:1 F:0]
06/17/09 16:17:27.651864 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/17/09 16:17:27.651874 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/17/09 16:17:31.152282 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/17/09 16:17:31.152342 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/17/09 16:17:31.152354 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1245244651.152, Z:100, E:1 F:0]
06/17/09 16:17:31.152399 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/17/09 16:17:31.152409 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
