Page 1 of 1
TVIP400w No Picture with /MJPEG.CGI but works with /IMAGE.JP
Posted: Tue Jun 09, 2009 9:35 pm
by seank
I have spent a few hours looking for A's and playing with settings but still no picture with 1.23.3.
My TVIP400w works fine on 1.24, except that the PTZ driver is for 1.23. So I have installed 1.23x with apt-get install zoneminder on ubuntu 8.1 which gives me 1.23.3.
I can get a picture at .86 frames per second if I use /IMAGE.JPG as the source path. If I use /MJPEG.CGI like I did on 1.24 I dont get a picture. My apache logs are clean. But I get this error in zmdebug with MJPEG.CGI
remote_camera.cpp/880 [Unable to extract subheader from stream, retrying]
Any input would be appriciated
thx
Posted: Tue Jun 09, 2009 9:56 pm
by seank
ZM_NETCAM_REGEXPS set to 0 and it is now working. Hopefully this post helps someone else :)
Posted: Mon Jun 22, 2009 3:53 am
by Normando
seank wrote:ZM_NETCAM_REGEXPS set to 0 and it is now working. Hopefully this post helps someone else :)
THANK YOU VERY MUCH!!!!!
Posted: Mon Jun 22, 2009 7:22 am
by syndacate
Where can I find the "ZM_NETCAM_REGEXPS" option?? I have no idea, and iI'm totally new to ZM...thank you
Posted: Mon Jun 22, 2009 1:30 pm
by Normando
Go to "Options" -> "Network" and uncheck "ZM_NETCAM_REGEXPS"
Posted: Tue Jun 23, 2009 7:31 am
by syndacate
Thnak you....i tried it but it didn't work! I haven't that camera but another one similar with a cgi path...! I opened another thread about that...if someone could help me......
