Page 1 of 1
Print special things on Webcam Images (zmtrigger.pl)
Posted: Wed Jun 10, 2009 5:58 pm
by lukelukeluke
Hi, I wondered if there was a solution to print more than timestamps on Zoneminder generated images. I know you can display the time and title, but I would like to display output of an external application on it, for example display the temperature with something like:
`cat /tmp/curtemp`.
I've seen in the manual that there is
ZoneMinder-1.23.3/scripts/zmtrigger.pl:
‘showtext’ is up to 32 characters of text that can be displayed in the timestamp that is added to images. The ‘show’ action is designed to update this text without affecting alarms but the text is updated, if present, for any of the actions. This is designed to allow external input to appear on the images captured, for instance temperature or personnel identity etc.
But I can't find an instruction on how to use zmtrigger...?
Posted: Tue Jun 16, 2009 6:22 pm
by lukelukeluke
Since no one answered, I tried the following workaround for my problem:
I wrote an external PHP-Script, which changes the Database entry Monitors.LabelFormat which I wanted to execute every 5 minutes. But apparently the change of this entry doesnt effect the timestamp on the image, even tough the Monitors Timestamp settings are updated in the settings pane - but the Monitor is only updated correctly when the Save button is pressed within Zoneminder.
Does anyone know a workaround for my workaround?
Posted: Sun Jun 28, 2009 9:34 am
by lukelukeluke
Normando posted the solution in
this topic:
Normando wrote:1- Comment those channels you will not use. In my case I only use port 6802 to control zmtrigger.pl, so comment the rest of connection in zmtrigger.pl
my @connections;
push( @connections, ZoneMinder::Trigger::Connection->new( name=>"Chan1", channel=>ZoneMinder::Trigger::Channel::Inet->new( port=>6802 ), mode=>"rw" ) );
#push( @connections, ZoneMinder::Trigger::Connection->new( name=>"Chan2", channel=>ZoneMinder::Trigger::Channel::Unix->new( path=>'/tmp/test.sock' ), mode=>"rw" ) );
#push( @connections, ZoneMinder::Trigger::Connection->new( name=>"Chan3", channel=>ZoneMinder::Trigger::Channel::File->new( path=>'/tmp/zmtrigger.out' ), mode=>"w" ) );
#push( @connections, ZoneMinder::Trigger::Connection->new( name=>"Chan4", channel=>ZoneMinder::Trigger::Channel::Serial->new( path=>'/dev/ttyS0' ), mode=>"rw" ) );
2- Enable triggers in options and restart zm
3- Send the command to the port 6802. You can make a script in php to access the socket in that port or send directly with your external app. I have write my own php script:
$cfgServer = "localhost";
$cfgPort = 6802;
$cfgTimeOut = 10;
if ($extTrigger) {
// open a socket
if(!$cfgTimeOut) {
// without timeout
@$conn_handle = fsockopen($cfgServer, $cfgPort);
}else{
// with timeout
@$conn_handle = fsockopen($cfgServer, $cfgPort, &$errno, &$errstr, $cfgTimeOut);
if(!$conn_handle) {
// echo "Connexion failed ";
echo "E1";
exit();
}else{
// echo "Connected ";
echo "E0";
fputs($conn_handle, $extTrigger);
// close connexion
fclose($conn_handle);
4- Add the token %Q at the end of timestamp string in your monitor settings, or where you want.
5- Change the monitor function to NoDect, MoCord or MoDect. If you want more functions to use external trigger look at
http://www.zoneminder.com/forums/viewtopic.php?t=12926
6- Send the command. In my case because script, I send via URL:
http://myserver/zm/myscript.php?extTrigger=<id>|<action>|<score>|<cause>|<text>|<showtex>
in your case
http://myserver/zm/myscript.php?extTrigger=1|show||||your_text
Reply the results
Posted: Tue Jun 30, 2009 11:08 pm
by ludri
Thanks this works for me too.
Posted: Sun Sep 27, 2009 12:49 am
by whatboy
Wonder how can you past info from a file, I have a weather station, and I generate a file every 5 minutes with temp, wind, rain, etc... and wanted to pass that info from the file to Zoneminder...
Posted: Sun Sep 27, 2009 10:00 am
by lukelukeluke
If you used the php version, you could just do a little shell script that would open that file (a certain information from it) and call the PHP script with your information:
VAR=`cat /path/to/your/file | grep line`
wget http://myserver/zm/myscript.php?extTrigger=1|show||||$VAR
For more info:
man cat
man grep
man wget
Posted: Mon Jan 10, 2011 5:57 am
by ohmeega
Can I add another webcam to a computer that already has an integrated webcam? I recently bought a Dell. I don't like the quality of the image that the integrated webcam has, therefore I would rather keep my old webcam. Will there be any interference if I install my old webcam?
______________________
external keyword tool ~
keyworddiscovery.com ~
keycompete.com ~
compete.com ~
webmasterworld.com
