Page 1 of 1
only 1 fps per second is record
Posted: Mon Jun 15, 2009 9:57 pm
by Osvaldo2009
ZM works well, but only charged 1 frame per second.
The film is to jump in jump.
What is more taxing frames per second?
config:
Remote Protocol HTTP
Remote Method simple
type image jpg
port 80
fps 25.00
Alarm Maximum FPS 25.00
Reference Image Blend %ge 15
thanks.
Posted: Mon Jun 15, 2009 11:59 pm
by kingofkya
i dont understand what you asking
is greater fps more taxing? yes
Posted: Tue Jun 16, 2009 12:12 pm
by Osvaldo2009
Hi
Now only 1fps per seconds is saved.
I need save 15fps or more per seconds.
How to?
thanks.
ZM config:
type image jpg
port 80
fps 25.00
Posted: Tue Jun 16, 2009 3:58 pm
by jameswilson
sounds like your camera is only sending 1 fps, so its irrlevant what you set in your zm config.
Whats the camera
Posted: Fri Jun 19, 2009 9:44 am
by Osvaldo2009
Hi jameswilson
The ip cam is vivotek 7330, it's work jpg at 25fps.
Thanks.
