Page 1 of 1
video generation script
Posted: Wed Jun 17, 2009 1:04 am
by rockmanchile
Hi all..
Im writing a little program to burn DVD`s over the web interface of ZM so the user can make bakcups of the alarms and events.
The thing is that i need to make a little script that can automatically converts the large number of jpegs images into an MPG or AVI video (just like ZM does from the console but from the command line)
I know that ZM uses ffmpeg for this purpose but until now i can´t get the correct command string.
The idea is simple, automatize the video generation.
Can you help me?
Best regards.
Eric.
P.S: Excuse my english.
Posted: Wed Jun 17, 2009 6:25 am
by kingofkya
dvds taake forever to make but here us a start for you
http://joerghaeger.de/webCDwriter/
http://www.zoneminder.com/forums/viewto ... +jpegs+mpg
also as far as ffmpeg
ffmpeg -i *.jpg output.mpeg
Posted: Wed Jun 17, 2009 7:03 pm
by rockmanchile
This is wath i get when i try to generate a video:
video-vigilancia:/var/www/zm/events/4/2214# ffmpeg -i *.jpg output.mpeg
FFmpeg version r11872+debian_0.svn20080206-17+lenny1, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-libfaad --enable-pp --enable-swscaler --enable-x11grab --prefix=/usr --enable-libgsm --enable-libtheora --enable-libvorbis --enable-pthreads --disable-strip --enable-libdc1394 --disable-armv5te --disable-armv6 --disable-altivec --disable-vis --enable-shared --disable-static
libavutil version: 49.6.0
libavcodec version: 51.50.0
libavformat version: 52.7.0
libavdevice version: 52.0.0
built on Apr 28 2009 02:12:01, gcc: 4.3.2
Input #0, image2, from '001-capture.jpg':
Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, yuvj420p, 320x240 [PAR 1:1 DAR 4:3], 25.00 tb(r)
Unable to find a suitable output format for '002-capture.jpg'
Wath im doing wrong?
Posted: Sat Jun 20, 2009 8:17 am
by vanbosco
Hi rockmanchile, i have made 3 simple script for my personal use that uses cron to generate avi video from events using ffmpeg.
Perhaps you can use these script as a starting point for your purpose.
ab_trova_eventi:
#!/bin/bash
DIR=/media/sda6/events_rolling/1/
DIR1=/media/sda6/events_intrepi/1/
DIR2=/media/sda6/events_sidXFCE/1/
DIR3=/media/sda6/events___lenny/1/
find "$DIR" -type d -exec ab_genera_video_lowres {} \;
find "$DIR1" -type d -exec ab_genera_video_lowres {} \;
find "$DIR2" -type d -exec ab_genera_video_lowres {} \;
find "$DIR3" -type d -exec ab_genera_video_lowres {} \;
ab_genera_video_lowres:
#!/bin/bash
#copiare in /usr/bin assieme a trova_eventi
#min e max sono le ore di inizio e fine archiviazione
min=6
max=22
let "min -= 1"
for i in $@
do
cd $i
if [ -e "001-capture.jpg" ]; then
ora=$(date --reference=001-capture.jpg +%H)
nome_video_anno=$(date --reference=001-capture.jpg +%F)
nome_video_ora=$(date --reference=001-capture.jpg +%H)
nome_video_minuti=$(date --reference=001-capture.jpg +%M)
nome_video_secondi=$(date --reference=001-capture.jpg +%S)
nome_video=$nome_video_anno"_"$nome_video_ora"_"$nome_video_minuti"_"$nome_video_secondi
if [ $ora -gt $min ]; then
if [ $ora -lt $max ]; then
if [ ! -e "fatto" ]; then
mkdir /media/sda5/videosorveglianza/Bassa_Risoluzione/$nome_video_anno
chown vanbosco:vanbosco /media/sda5/videosorveglianza/Bassa_Risoluzione/$nome_video_anno
ffmpeg -r 4 -i %03d-capture.jpg -b 180k /media/sda5/videosorveglianza/Bassa_Risoluzione/$nome_video_anno/$nome_video.avi
chown vanbosco:vanbosco /media/sda5/videosorveglianza/Bassa_Risoluzione/$nome_video_anno/$nome_video.avi
touch fatto
chown www-data:www-data fatto
fi
fi
fi
fi
done
video_lowres:
video_lowres is in my home directory and is used by cron to launch the other scripts that are in /usr/bin.
In the ffmpeg string -r 4 is my capture rate and -b 180k is the bitrate of generated video, in this way three days of events from 6 am to 10 pm generates about 3.6 GB of video (320x240).
Best regards, Arnaldo.
