probably pretty easy to fix
alf
Post by alf »
Unbuntu 9.04
zoneminder 1.24
I was planing on puzzling out zoneminder on a spare slow machine then putting it on the fast one that already runs the monitor system. There is only 256 megs of mem so I think this is the issue.
I can see the cameras with xawTV, and am using the cards suggested by this web page.
The problem is that when I boot I can see the cameras and then after a bit they stop working and go black or blank out.
So its either a configuration problem or the slow system.
kingofkya
Post by kingofkya »
try running htop see if cpu is maxed for a long time
