Page 1 of 1
troubleshooting email sending - Ubuntu 9.04 zm 1.24
Posted: Fri Jun 19, 2009 2:54 pm
by sgreszcz
I downloaded the .deb file and installed zoneminder 1.24. All seems to be working OK, except I can't get the email alerting on alarms to work...
I am using ssmtp as my MTA, and I have tested that it is working using mutt to send an email and can see evidence of the sending in /var/log/mail.log
I can see that zoneminder is trying to generate the email:
Jun 19 15:41:02 247 zmfilter[11757]: INF [Creating notification email]
Jun 19 15:41:02 247 zmfilter[11757]: INF [Sending notification email 'ZoneMinder: Alarm - Cam-152 (5 - 5 3)']
Jun 19 15:41:02 247 zmfilter[11757]: INF [Attaching '/usr/share/zoneminder/events/1/152/011-capture.jpg]
but for some reason it isn't sending to localhost to be relayed out.
I have tried both perl methods as configured in zoneminder.
Can someone give me some suggestions on how to further troubleshoot this?
Thank you.
Posted: Sun Jun 21, 2009 4:58 am
by henriquejf
yes, i have a suggestion for you, an wiki article i have published that covers that and more; please tell me if you think that was somehow useful;
http://www.zoneminder.com/wiki/index.ph ... rver_32bit
luck !
Posted: Wed Jun 24, 2009 12:14 am
by rtm
Henriquejf - it was very helpful to me! Since I didn't have enough space to ftp all the images ZM is creating, your email fix now gets me something to alert me to any issues. Thanks!
(fyi - after playing around I found that %ED% and %ET% will put in the event date and time - I think that is useful to know when the alert happened versus counting that the email was delivered 'on time'. I tried to find where all of those codes may be, but alas, could not find any except what you posted. Thanks again!)
attachment zm codes
Posted: Wed Jun 24, 2009 3:04 am
by henriquejf
ok rtm, good to know ! the complete reference is in the documentation here:
http://www.zoneminder.com/wiki/index.php/Documentation
and what we want in it is
%EI% Id of the event
%EN% Name of the event
%EC% Cause of the event
%ED% Event description
%ET% Time of the event
%EL% Length of the event
%EF% Number of frames in the event
%EFA% Number of alarm frames in the event
%EST% Total score of the event
%ESA% Average score of the event
%ESM% Maximum score of the event
%EP% Path to the event
%EPS% Path to the event stream
%EPI% Path to the event images
%EPI1% Path to the first alarmed event image
%EPIM% Path to the (first) event image with the highest score
%EI1% Attach first alarmed event image
%EIM% Attach (first) event image with the highest score
%EV% Attach event mpeg video
%MN% Name of the monitor
%MET% Total number of events for the monitor
%MEH% Number of events for the monitor in the last hour
%MED% Number of events for the monitor in the last day
%MEW% Number of events for the monitor in the last week
%MEM% Number of events for the monitor in the last month
%MEA% Number of archived events for the monitor
%MP% Path to the monitor window
%MPS% Path to the monitor stream
%MPI% Path to the monitor recent image
%FN% Name of the current filter that matched
%FP% Path to the current filter that matched
%ZP% Path to your ZoneMinder console
cheers
Posted: Sat Jun 27, 2009 12:50 pm
by rtm
Thanks, and I found from reading another post that %ED% doesn't do anything - %ET% was giving date AND time.
Posted: Tue Jan 12, 2010 10:04 pm
by dcbour
Question...where would I find these defined - are they in a file...or the database. I would like to edit the variable presented so I can embed the authentication and skin selection in the string passed. I've grepped the files and checked through the database to no avail.
Thanks!
Posted: Sat Nov 20, 2010 3:00 pm
by PacoLM
Hi henriquejf,
Followed your email setup guide with postfix, it worked perfect in my Guruplug system, thanks a lot.
PacoLM
