I'm on Ubuntu Intrepid. I've done these directions to the letter:
http://www.zoneminder.com/wiki/index.ph ... ozola-0.7)
I have no errors in the Apache log and obviously with xawtv working, the BT878 drivers are in good shape.
I've turned ZM's diagnostics logging to "9" and wished I could turn 'em up to "11" (gratuitous Spinal Tap reference).
I have some strange stuff going on at /var/log/messages:
Jun 20 18:12:42 zmuser-camerastation zmdc[5789]: INF [Starting pending process, zmc -d /dev/video0]
Jun 20 18:12:42 zmuser-camerastation zmdc[9407]: INF ['zmc -d /dev/video0' started at 09/06/20 18:12:42]
Jun 20 18:12:42 zmuser-camerastation zmdc[5789]: INF ['zmc -d /dev/video0' starting at 09/06/20 18:12:42, pid = 9407]
Jun 20 18:12:42 zmuser-camerastation zmc_dvideo0[9407]: INF [Debug Level = 0, Debug Log = <none>]
Jun 20 18:12:42 zmuser-camerastation zmc_dvideo0[9407]: INF [New Debug Level = 9, New Debug Log = /tmp/zm_debug.log.09407]
Jun 20 18:12:42 zmuser-camerastation zmc_dvideo0[9407]: INF [Starting Capture]
Jun 20 18:12:42 zmuser-camerastation zmc_dvideo0[9407]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Jun 20 18:12:42 zmuser-camerastation zmc_dvideo0[9407]: INF [Backtrace complete, please execute the following command for more information]
Jun 20 18:12:42 zmuser-camerastation zmc_dvideo0[9407]: INF [addr2line -e /usr/local/bin/zmc 0xb8096430 0xb8096430 0xb71bb8a0 0xb71bd268 0x805634d 0x806a07f 0x806a9b4 0x804d0fb 0xb71a6685 0x804cc61]
Jun 20 18:12:42 zmuser-camerastation zma_m4[5815]: WAR [Waiting for capture daemon]
Jun 20 18:13:13 zmuser-camerastation last message repeated 31 times
There's also odd stuff in the zm_debug logs at /tmp:
06/20/09 18:12:42.289984 zmc_dvideo0[9407].DB1-zm_monitor.cpp/1814 [Loaded monitor 4(Cam1), 1 zones]
06/20/09 18:12:42.290066 zmc_dvideo0[9407].INF-zmc.cpp/188 [Starting Capture]
06/20/09 18:12:42.290355 zmc_dvideo0[9407].DB3-zm_local_camera.cpp/349 [Opening video device /dev/video0]
06/20/09 18:12:42.290462 zmc_dvideo0[9407].DB2-zm_local_camera.cpp/355 [V4L2 support enabled, using V4L2 api]
06/20/09 18:12:42.290492 zmc_dvideo0[9407].DB3-zm_local_camera.cpp/360 [Checking video device capabilities]
06/20/09 18:12:42.290534 zmc_dvideo0[9407].DB3-zm_local_camera.cpp/370 [Setting up video format]
06/20/09 18:12:42.290597 zmc_dvideo0[9407].FAT-zm_local_camera.cpp/386 [Failed to set video format: Invalid argument]
06/20/09 18:12:42.290840 zmc_dvideo0[9407].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
06/20/09 18:12:42.291044 zmc_dvideo0[9407].ERR-zm_signal.cpp/84 [Signal address is (nil), from 0xb8096430]
06/20/09 18:12:42.291579 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: [0xb8096430]]
06/20/09 18:12:42.291725 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: [0xb8096430]]
06/20/09 18:12:42.291856 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(gsignal+0x50) [0xb71bb8a0]]
06/20/09 18:12:42.292007 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(abort+0x188) [0xb71bd268]]
06/20/09 18:12:42.292145 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x805634d]]
06/20/09 18:12:42.292283 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x806a07f]]
06/20/09 18:12:42.292421 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x806a9b4]]
06/20/09 18:12:42.292558 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804d0fb]]
06/20/09 18:12:42.293384 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5) [0xb71a6685]]
06/20/09 18:12:42.293552 zmc_dvideo0[9407].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804cc61]]
06/20/09 18:12:42.293699 zmc_dvideo0[9407].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
06/20/09 18:12:42.293847 zmc_dvideo0[9407].INF-zm_signal.cpp/126 [addr2line -e /usr/local/bin/zmc 0xb8096430 0xb8096430 0xb71bb8a0 0xb71bd268 0x805634d 0x806a07f 0x806a9b4 0x804d0fb 0xb71a6685 0x804cc61]
Thanks,
Jim
