1970-01-01 01:00:00
afiordipelle
1970-01-01 01:00:00
Post by afiordipelle »
Hello, we installed ZM 1.24.1 and it works with 5 cameras: 3 linksys and 2 Panasonic. I configured some filters to sending mails and all seems ok... but sometimes we receive mail like this:
Attenzione.
ZoneMinder ha rilevato un movimento:
Telecamera : %MN%
ID Evento : %EI%
Orario Evento: %ET%
Lunghezza : %EL%
Frames : totali%EF% (attivi%EFA%)
Scores : totale%EST% max%ESM% medio%ESA%
Visualizza questo allarme, rilevato dal filtro %FN%, in questa schermata: %EPS%
ZoneMinder
Where %ET% is 1970-01-01 01:00:00
and %EL% is a very big negative number
If I look events on zm console, I see events like this:
10454 Event-10454 camera_4 Motion 01/01 01:00:00 -219813.27 36 9 81 9 12
and if I look the event I see this:
Frames - 10454
Frame Id Type Time Stamp Time Delta Score
1 Normal 01:00:00 0.00 0
2 Normal 01:00:00 0.00 0
3 Normal 01:00:00 0.00 0
4 Normal 01:00:00 0.00 0
5 Normal 01:00:00 0.00 0
6 Normal 01:00:00 0.00 0
7 Normal 01:00:00 0.00 0
8 Normal 01:00:00 0.00 0
9 Normal 01:00:00 0.00 0
10 Normal 12:25:00 -219,815.81 0
11 Alarm 12:25:00 -219,815.76 6
12 Normal 12:25:00 -219,815.69 0
13 Normal 12:25:00 -219,815.59 0
14 Normal 12:25:00 -219,815.49 0
15 Normal 12:25:00 -219,815.39 0
16 Normal 12:25:00 -219,815.29 0
17 Normal 12:25:00 -219,815.19 0
18 Normal 12:25:00 -219,815.09 0
19 Alarm 12:25:00 -219,814.99 6
20 Alarm 12:25:00 -219,814.89 7
21 Alarm 12:25:01 -219,814.79 8
22 Alarm 12:25:01 -219,814.69 10
23 Alarm 12:25:01 -219,814.59 12
24 Alarm 12:25:01 -219,814.49 12
25 Alarm 12:25:01 -219,814.39 11
26 Alarm 12:25:01 -219,814.29 9
27 Normal 12:25:01 -219,814.18 0
28 Normal 12:25:01 -219,814.08 0
29 Normal 12:25:01 -219,813.98 0
30 Normal 12:25:01 -219,813.88 0
31 Normal 12:25:02 -219,813.78 0
32 Normal 12:25:02 -219,813.68 0
33 Normal 12:25:02 -219,813.58 0
34 Normal 12:25:02 -219,813.48 0
35 Normal 12:25:02 -219,813.38 0
36 Normal 12:25:02 -219,813.27 0
So I think the problem is date of pre-event frame.
What have -I to do to fix the problem?
Thank you very much
Normando
Post by Normando »
I don't know if it is related, but I was have the same issue with ZM 1.23.3. Look at
http://www.zoneminder.com/forums/viewtopic.php?t=12943
and
http://www.zoneminder.com/forums/viewto ... 8574#48574
