I found a couple threads where people spoke of the EasyCap USB. On DealTime you can pick them up for around $12:
http://www.dealextreme.com/details.dx/sku.11127
There were a couple projects I found where people were getting them to work with Linux:
http://sourceforge.net/forum/forum.php? ... _id=616182
and
http://ubuntuforums.org/showthread.php?t=924504
Has anyone got one of these to work with Zoneminder? I have a box with one PCI-X slot and was trying to avoid purchasing an 8 channel card to add some more cameras.
EasyCap USB
Your kind of on your own with that hardware but it looks like you might have a shot
I would be interested to see if theses work. It would be great with the modified routers.
I would say try it $12 buck is cheap for hardware post back if you do go with it.
also if you can check for conflicts by puging in 2 of them.
http://sourceforge.net/forum/message.php?msg_id=7467188I compiled the patched drivers for stk1160 4 CH and they works with program that are able to set or switch between the four channels, like xawtv, zoneminder, etc. ...
Easycap USB video framegrabber
Google for Easycap DC60, Easycap DC60++ or XP STK1150.
For example http://ubuntuforums.org/showthread.php?p=8988921
I've recently uploaded version 0.8.3 of the Linux device driver for the EasyCAP DC60:
http://sourceforge.net/projects/easycapdc60/
With two inputs on a single 4-CVBS EasyCAP I am seeing about 1 frame per second for each input in the ZoneMinder console.
Mike
Mike
