UVC Video, Get higher Resolution than 320x240 [SOLVED]
Posted: Thu Jul 02, 2009 11:22 pm
Hi there,
i just bought a Philips SPC 1330 NC which is fully supported
under Linux throw the UVCvideo Module. Started some tests,
its all running fine.
The Camera has a Resolution up to 1280x960 and up to 90 fps.
So i read the Wiki
And i configured as explained, and its running fine. But i was wondering,
why i couldnt change the Resolution up to 640x480. mjpg-streamer is running
fine in 320x240 and 640x480. VLC and Firefox can grab the Picture.
Why isnt Zoneminder able to work with the higher Resolution.
I also found and read this
Would be happy for answers.
Btw i tryed as explained in some other linux forums,
Applying the changes to mjpg-streamer and zoneminder i only do get a
black picture.
Are there any recent changes that makes it easier or replace the mjpg-steamer?
Thanks a lot.
So i read the Wiki
http://www.zoneminder.com/wiki/index.php/Uvc
But i am asking my self why and searching for an solution, 320x240 might be deprecated for some newer models.Note: Currently the only supported resolution is: 320x240. mjpg_streamer defaults to 640x480, so make sure to declare the necessary resolution when running the program (see below.)
http://ubuntuforums.org/showthread.php?t=882863
black picture.
Thanks a lot.
