Enabling ZM user auth, Firefox cannot see video, IE is ok...
skyhook
Post by skyhook »
Enabling ZM user auth, Firefox cannot see video, IE still work fine...
Somebody can check it?
tnx ;)
quietas
Post by quietas »
I have a test box using an SVN download from a couple weeks ago which seemed fine with both IE and Firefox with ZM auth turned on.
cordel
Post by cordel »
If you want to give one of us access to your box we can check it. My installations don't seem to suffer from this.
skyhook
Post by skyhook »
cordel wrote:If you want to give one of us access to your box we can check it. My installations don't seem to suffer from this.
TNX, but now work fine :(
td
Post by td »
Hello skyhook,
it's a typical behaviour if you switch on user authentication. You the have to log out and log in again to avoid this.
TD
