Hi, I am interested in a new feature for ZM, would be perfect to get once day an email notification that ZM system and all cameras (analog & IP) are running.
Do you have some ideas or experiences with this?
Thanks.
J.
Periodical email inform of running system and cameras
Maybe you should try bash or perl for making an script which connects to database and selects the state of your cameras, then email it using a cron job.
I haven't found any option on zoneminder that can do that.
I already did a similar perl script that connected to a postgresql database, that won't work for you but here is a part:
#!/usr/bin/perl -w
#use strict;
use CGI qw(:standard);
use DBI;
#make script that connects to database and stores data on $databasedata
#this will send the email
#You need to have sendmail and perl of course
envio("test\@domain.com","other\@domain.com","Subject ",$databasedata);
sub envio {
my ($email, $otro_email ,$subject,$message) = @_;
open MAIL, "| /usr/lib/sendmail -t -i" or die "Can't open sendmail: $!";
print MAIL <<END_OF_MESSAGE;
To: $email
Reply-To: $otro_email
Subject: $subject
Mail send using sendmail and perl:
$message
END_OF_MESSAGE
close MAIL or die "Error cerrando sendmail: $!";
