I need to generate a video out of the captured jpg images which zomeminder generates in the /var/cache/zoneminder/events/... sub-directories. For me the easiest way to do this in an automatic way, is to set up a cron job which generates one video every day and than deletes all jpgs which have been merged into the daily video.
I decided to use the mencoder to merge all jpg images into a video. The command I use so far is:
mencoder mf://*.jpg -mf w=320:h=240:fps=25:type=jpg -ovc lavc -lavcopts vcodec=mpeg4:mbd=2:trell -oac copy -o output.avi
Perhaps some backgrounds to the used hardware: I'm using the PV-143 - 4 port video capture card (http://store.bluecherry.net/Provideo_PV ... -143na.htm). To my understanding, it means that 7.5 frames per second are captured per input. However, when I check a camera in zoneminder I see an alarm status: Alarm - 2.11 fps. Hmm ... not good
But I need to know how to configure mencoder in such a way that the video isn't played too fast or too slow.
Thank you,
Ralf
