Windows Server - Virtualised ZoneMinder
Posted: Tue Jul 14, 2009 5:24 pm
Has anybody successfully run ZoneMinder inside a virtual machine on a Windows Server 2003 or Server 2008 box?
I currently have a Windows Server for my TV tuners and a Linux server for ZoneMinder. It works well (although at almost 10 years old the machines are sometimes a bit kranky about power up after a power failure) but I'd ideally like to get just the one system. I've looked into replacing ZoneMinder with a Windows-based solution and nothing comes close; similarly nothing on Linux comes close to DVBViewer (MythTV isn't suitable for me).
I can see two possibilities for going about this:
1) Use USB analogue tuners with virtual USB controllers. VirtualBox and VMWare seem to support sharing real USB hardware with a virtual machine, but so far my attempts at getting this to work have failed.
2) Use PCI tuners with a Windows-side app to take the composite input and stream as MJPEG. This can theoretically be added as a psuedo-IP-Cam within the virtual ZoneMinder.
It is this latter approach that I'm pursuing, but again I seem to have hit a brick wall because I'm unable to find anything on Windows that can stream MJPEG from a TV card.
So my question is - does anybody know of an application that can take the input from the standard WDM-compatible TV tuner and create a real-time(ish) MJPEG stream?
