Trendnet TV-IP200 help anyone? (WORKING)
quirk
Post by quirk »
Someone posted some stuff in the wrong forum so am posting in here for help on a Trendnet TV-IP200 webcam. I get a nice picture out going directly to the camera and looking at it with the JAVA app. Can't get the active X to work but that is probably because I am on Windows 7.
Here are my current settings and I still have not gotten a picture on ZM.
General
Source Type: Remote
Enabled: Yes
Linked Monitors: Dark-Eye
Max FPS:
Alarm Max FPS:
Reference Image Bkebd %ge: 7
Triggers:
Source
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: guest:guest@10.50.5.99
Remote Host Port: 80
Remote Host Path: /goform/capture
Remote Image Colours: 24bit
Capture Width: 640
Capture Height 480
Preserve Aspect Ratio:
Orientation: Normal
I have tried the TV-IP100 method
Source
Remote Host Path: video.cgi
Capture Width: 640
Capture Height 480
Orientation: Normal
I have also tried the steps for the TV-IP300
ZM_HTTP_VERSION = 1.0
Path = /cgi-bin/video.jpg
quirk
Post by quirk »
Ok here is an update. All I see is a black screen. Going to have to check when I get home. The camera is still set at 640X480 but I bumped my capture down to 320X240.
quirk
Post by quirk »
Had to set the ipcamera back to 320X480
Settings are as follows.
Streaming - 7fps to 30fps Depends on camera side compression
General
Source Type: Remote
Enabled: Yes
Max FPS:
Alarm Max FPS:
Triggers:
Source
Remote Host Path: /video.cgi
Capture Width: 320
Capture Height 240
Orientation: Normal
JPEG Capture - 2.5fps
General
Source Type: Remote
Enabled: Yes
Max FPS:
Alarm Max FPS:
Triggers:
Source
Remote Host Path: /image.jpg
Capture Width: 320
Capture Height 240
Orientation: Normal
