PV-149P freezes system completely [solved]
Posted: Sat Jul 18, 2009 7:00 pm
Hello
I bought on of the legendary bluecherry PV149 which is nicely recognised and works out of the box apart from one thing: after a few seconds of grabbing it entirely freezes up the system. Has anyone heard of this before or should I suspect defective hardware?
Suse 11.1 dual Opteron 64
Linux version 2.6.27.23-0.1-default #1 SMP
Asus motherboard, 4G of registered first class ram fully tested,
I tried the card with mplayer as well with the same freezes happeneing. If I use my pinnacle dazzle Dv100 grabbing works fine with both zm and mplayer.
HELP!
thanks
alex
following a few 'famous last words' from /var/log/messages:
Jul 18 16:11:47 mother kernel: BUG: unable to handle kernel paging request at ffff8800d1b0acc9
Jul 18 16:11:47 mother kernel: IP: [<ffffffff802ab39b>] free_block+0x75/0x126
Jul 18 16:11:47 mother kernel: PGD 202063 PUD 0
Jul 18 16:11:47 mother kernel: Oops: 0002 [1] SMP
Jul 18 16:11:47 mother kernel: last sysfs file: /sys/devices/system/cpu/cpu1/cache/index2/shared_cpu_map
Jul 18 16:11:47 mother kernel: CPU 1
Jul 18 16:11:47 mother kernel: Modules linked in: ip6t_LOG xt_tcpudp xt_pkttype ipt_LOG xt_limit nfsd lockd nfs_acl auth_rpcgss sunrpc exportfs binfmt_misc snd_pcm_oss snd_mixer_oss snd_seq_midi snd_seq_midi_event snd_seq ip6t_REJECT nf_conntrack_ipv6 ip6table_raw xt_NOTRACK ipt_REJECT xt_state iptable_raw iptable_filter ip6table_mangle nf_conntrack_netbios_ns nf_conntrack_ipv4 nf_conntrack ip_tables ip6table_filter ip6_tables x_tables ipv6 cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 nls_iso8859_1 nls_cp437 vfat fat fuse loop dm_mod snd_mpu401 rtc_cmos tda1004x(N) ppdev snd_mpu401_uart rtc_core ns558 rtc_lib joydev gameport pcspkr k8temp(N) tg3 nvidia(PX) libphy bttv budget_av(N) ir_common compat_ioctl32 i2c_algo_bit saa7146_vv v4l2_common btcx_risc videobuf_dma_sg tveeprom videobuf_core videodev v4l1_compat parport_pc parport floppy snd_usb_audio snd_intel8x0 budget_core(N) ohci1394 snd_ac97_codec snd_usb_lib dvb_core(N) cfi_cmdset_0002(N) cfi_util(N) ac97_bus ieee1394 jedec_probe(N) i2
Jul 18 16:11:47 mother kernel: c_nforce2 saa7146 cfi_probe(N) button gen_probe(N) snd_rawmidi ttpci_eeprom(N) snd_pcm snd_seq_device snd_timer ck804xrom(N) shpchp i2c_core snd_hwdep snd mtd pci_hotplug soundcore chipreg(N) snd_page_alloc usblp map_funcs(N) usbhid usb_storage hid sr_mod cdrom ff_memless sg raid456 async_xor async_memcpy async_tx xor raid0 sd_mod ehci_hcd crc_t10dif ohci_hcd usbcore edd raid1 ext3 mbcache jbd fan ide_pci_generic amd74xx ide_core ata_generic pata_amd sata_sil sata_nv libata scsi_mod dock thermal processor thermal_sys hwmon
Jul 18 16:11:47 mother kernel: Supported: No
Jul 18 16:11:47 mother kernel: Pid: 5185, comm: plasma Tainted: P 2.6.27.23-0.1-default #1
Jul 18 16:11:47 mother kernel: RIP: 0010:[<ffffffff802ab39b>] [<ffffffff802ab39b>] free_block+0x75/0x126
Jul 18 16:11:47 mother kernel: RSP: 0018:ffff880070475d48 EFLAGS: 00010002
Jul 18 16:11:47 mother kernel: RAX: ffff88009a952000 RBX: ffff88007fc92b80 RCX: ffff8800bf8210c0
Jul 18 16:11:47 mother kernel: RDX: ffff8800d1b0acc1 RSI: ffff8800904ae000 RDI: ffff8800904aed98
Jul 18 16:11:47 mother kernel: RBP: ffff8800904aed98 R08: ffff8800bf820000 R09: ffff8800bf0d7818
Jul 18 16:11:47 mother kernel: R10: ffff88008121c548 R11: 0000000000000000 R12: 000000000000000d
Jul 18 16:11:47 mother kernel: R13: ffff8800bf0d7880 R14: 000000000000020d R15: 000000000000003c
Jul 18 16:11:47 mother kernel: FS: 00007f13bae64790(0000) GS:ffff8800bf05e340(0000) knlGS:0000000000000000
Jul 18 16:11:47 mother kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Jul 18 16:11:47 mother kernel: CR2: ffff8800d1b0acc9 CR3: 000000007046f000 CR4: 00000000000006e0
Jul 18 18:45:22 mother zmdc[23477]: INF [Starting pending process, zmfilter.pl]
Jul 18 18:45:22 mother zmdc[23477]: INF ['zmfilter.pl' starting at 09/07/18 18:45:22, pid = 24848]
Jul 18 18:45:22 mother zmdc[24848]: INF ['zmfilter.pl' started at 09/07/18 18:45:22]
Jul 18 18:45:22 mother zmdc[23477]: ERR ['zmfilter.pl ' exited abnormally, exit status 9]
Jul 18 18:50:50 mother zmdc[8586]: INF ['zmc -d /dev/video' starting at 09/07/18 18:50:50, pid = 9312]
Jul 18 18:50:50 mother zmdc[9312]: INF ['zmc -d /dev/video' started at 09/07/18 18:50:50]
Jul 18 18:50:51 mother zmc_dvideo[9312]: INF [Debug Level = 0, Debug Log = <none>]
Jul 18 18:50:51 mother zmc_dvideo[9312]: INF [Starting Capture]
Jul 18 18:50:52 mother zmdc[8586]: WAR [Can't find process with command of 'zma -m 1']
Jul 18 19:36:57 mother kernel: BUG: unable to handle kernel paging request at ffff8800c7884748
Jul 18 19:36:57 mother kernel: IP: [<ffffffff802ab39b>] free_block+0x75/0x126
Jul 18 19:36:57 mother kernel: PGD 202063 PUD 0
Jul 18 19:36:57 mother kernel: Oops: 0002 [1] SMP
Jul 18 19:36:57 mother kernel: last sysfs file: /sys/devices/system/cpu/cpu1/cache/index2/shared_cpu_map
Jul 18 19:36:57 mother kernel: CPU 0
Jul 18 19:36:57 mother kernel: Modules linked in: ip6t_LOG xt_tcpudp xt_pkttype ipt_LOG xt_limit nfsd lockd nfs_acl auth_rpcgss sunrpc exportfs binfmt_misc snd_pcm_oss snd_mixer_oss snd_seq_midi snd_seq_midi_event snd_seq ip6t_REJECT nf_conntrack_ipv6 ip6table_raw xt_NOTRACK ipt_REJECT xt_state iptable_raw iptable_filter ip6table_mangle nf_conntrack_netbios_ns nf_conntrack_ipv4 nf_conntrack ip_tables ip6table_filter ip6_tables x_tables ipv6 cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 nls_iso8859_1 nls_cp437 vfat fat fuse loop dm_mod tda1004x(N) saa7115 budget_av(N) saa7146_vv budget_core(N) cfi_cmdset_0002(N) cfi_util(N) dvb_core(N) jedec_probe(N) snd_mpu401 bttv cfi_probe(N) gen_probe(N) snd_mpu401_uart saa7146 ck804xrom(N) snd_usb_audio mtd snd_usb_lib i2c_algo_bit snd_rawmidi chipreg(N) snd_intel8x0 v4l2_common videobuf_dma_sg btcx_risc snd_ac97_codec em28xx compat_ioctl32 videodev v4l1_compat videobuf_vmalloc ppdev ac97_bus snd_seq_device videobuf_core rtc_cmos ns558 ttpci_eeprom(N)
Jul 18 19:36:57 mother kernel: usblp snd_pcm ir_common shpchp snd_timer snd_hwdep tg3 usb_storage sr_mod rtc_core parport_pc snd floppy rtc_lib parport libphy gameport map_funcs(N) pci_hotplug tveeprom soundcore button cdrom ohci1394 sg k8temp(N) i2c_nforce2 ieee1394 pcspkr nvidia(PX) snd_page_alloc i2c_core joydev usbhid hid ff_memless raid456 async_xor async_memcpy async_tx xor raid0 ehci_hcd sd_mod ohci_hcd crc_t10dif usbcore edd raid1 ext3 mbcache jbd fan ide_pci_generic amd74xx ide_core ata_generic pata_amd sata_sil sata_nv libata scsi_mod dock thermal processor thermal_sys hwmon
Jul 18 19:36:57 mother kernel: Supported: No
Jul 18 19:36:57 mother kernel: Pid: 18466, comm: bash Tainted: P 2.6.27.23-0.1-default #1
Jul 18 19:36:57 mother kernel: RIP: 0010:[<ffffffff802ab39b>] [<ffffffff802ab39b>] free_block+0x75/0x126
mother:/home/alex # sysctl -p
fs.inotify.max_user_watches = 65536
net.ipv4.conf.default.promote_secondaries = 1
net.ipv4.conf.all.promote_secondaries = 1
kernel.shmall = 2048000
kernel.shmmax = 4194304000
mother:/home/alex # ipcs -l
------ Gemeinsamer Speicher: Grenzen --------
Maximale Anzahl der Segmente = 4096
Maximale Segmentgröße (KByte) = 4096000
Maximaler gesamter gemeinsamer Speicher (kBytes) = 8192000
Minimale Segmentgröße (Bytes) = 1
------ Semaphorengrenzen --------
maximale Anzahl von Feldern = 1024
maximale Semaphoren pro Feld = 250
maximale Semaphoren systemweit = 256000
maximale Operations pro Semop-Ruf = 32
maximaler Semaphorenwert = 32767
------ Nachrichten: Grenzen --------
maximale Warteschlangen systemweit = 1506
maximale Größe der Nachricht (Bytes) = 65536
normale maximale Größe der Warteschlange (Bytes) = 65536
HELP!
thanks
alex
