I interested to buy some day/night infrared camera, the best choice is AXIS 221 + infrared light but is for me so expensive.
Do you know some others cheaper and with ZM compatibility?
Thank you.
J.
any recomendation of Infrared day/night IP camera?
I assume from the Axis you mentioned, you are wanting IP based cameras?
If analog worksthough , I really like the Q-See QSC48030. It's a fixed length camera with about 80ft of IR advertised (I can vouch for at least 60). Plus it is weatherproofed, has a mount and cable included.
Q-See QSC48030
Here's an image at night in the plenum airspace of one of my offices. This is comeplete darkness with the pipes at the far wall just visible. That wall is nearly 70 ft away and most of the IR light is blocked by the center beam there in the middle.
Q-See QSC48030
