Page 1 of 1
Calendar?
Posted: Mon Jul 20, 2009 2:35 pm
by robi
I've used happily the old calendar feature.
Release 1.23.0
# FEATURE : If you include the jscalendar javascript calendar (http://www.dynarch.com/projects/calendar/) in your ZM web dir in a 'calendar' subdirectory then filter date/time dialogs will use a popup calendar for easier date selection.
Is this gone from 1.24.x?
Posted: Mon Jul 20, 2009 10:32 pm
by kingofkya
mine is there using zm arch
Posted: Tue Jul 21, 2009 9:04 am
by robi
It doesn't work with my 1.24.2. The calendar subdirectory is under /var/www/zm. Any ideas?
Posted: Tue Jul 21, 2009 11:55 pm
by kingofkya
ok mine is in /webroot/zm/tools/jscalendar
i think the tools directory changed
Posted: Fri Jul 24, 2009 10:18 am
by robi
kingofkya wrote:ok mine is in /webroot/zm/tools/jscalendar
That did the trick, thanks.
