New Generic IP camera (Wireless)
Posted: Tue Jul 21, 2009 5:44 am
Hello all i have picked up a couple of new IP cameras and obviously cannot get them to work heehee. They came with absolutely no documentation I have contacted the supplier to see if i can get some infos from them they have not responded yet.
Can get the camera to work with internet explorer (requires and active X control to be installed) However It does not work with my MAC under any browser (firefox, seamonkey, or opera)
Have the camera added as the only monitor and always just get a black box.
I am using zoneminder version 1.24.1 and Arch Linux the ZMLarch CD built by rdmelin big thanks to rdmelin for his CD. I have tried several random setting for protocols and paths but do not really know were to begin so i hit the logs looking for errors found these.
07/20/09 22:39:17.816496 zmwatch[5463].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
07/20/09 22:39:17.816839 zmwatch[5463].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
07/20/09 22:59:32.609354 zmwatch[2931].INF [Watchdog starting]
07/20/09 22:59:32.678299 zmwatch[2931].INF [Watchdog pausing for 30 seconds]
==> /var/log/messages.log <==
Jul 20 23:09:31 263 zms[3045]: INF [Debug Level = 0, Debug Log = <none>]
Jul 20 23:09:31 263 zms[3045]: INF [Authenticated user 'user']
Jul 20 23:09:31 263 zms[3045]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Jul 20 23:09:31 263 zms[3045]: WAR [Unable to store frame as shared memory invalid]
Looked through the FAQ, and docs but might be a bit overwhelmed as to what to start looking/troubleshooting. Have looked through all the settings for the camera cannot really find anything to help me out.
PLEASE HELP
Here are the manufactures specs for the camera
Control levels administrator user and guest.
Alarm/ Recording
Motion detection, Email when alarm, Mobile Phone Surveillance
Schedule, Manual, Alarm Recording ,2/2 Alarm in/out
Pan/Tilt Control RS485
Browser Windows XP/Vista Version IE6.0 Version above NET4.5 Version above
CPU 32Bit RSIC Embedded Processor
OS Embedded Linux systemNetwork
ProtocolTCP/IP, HTTP, ARP, RARP, TCP, ICMP, DHCP, PPPOE, DDNS, SMTP etc.
Interface RJ45 10/ 100M Ethernet
VideoCompression MPEG-4
Frame Rate 10-30fps (D1)
Resolution D1: 720X576 CIF: 320X288 FIELD: 720X288 QCIF: 192X144
Input 1Ch
Output 1Ch Audio
CompressionADPCM
Input Built-in MIC / Two-way Audio
CCD Image Sensor 1/3 SONY, 480 TVL Optional
S/ N Ratio >48db (AGC OFF)
Min Illumination 0.5 LUX
Lens Interface CS/ C
White Balance Auto
BLC Auto
Wireless Protocol/Power IEEE802.11b/g, 14-17 Dbm
Power POE:Power over Ethernet (IEEE 802.3af) DC12V 1A
Dimension 157*61*61(mm)
Weight 0.712 KG
PLEASE HELP
Alarm/ Recording
Input 1Ch
Output 1Ch Audio
CompressionADPCM
White Balance Auto
BLC Auto
Weight 0.712 KG
