graphiccard's MPEG Encoder to avoid high cpu usage from ZMA?
Posted: Thu Jul 30, 2009 7:30 pm
Hi!
I have a capture card (without mpeg hardware encoder) with 8 channels...
I need to capture 2 cams with a resolution at least of 640x480 (grayscale) and at the same time 3 other cams > motion detect!
The problem is that i'm using just a 3ghz single processor computer and that "ZMA" is using 75% CPU usage when i record just one camera (640x480, grayscale, 10fps)
Is there a way to use the MPEG Encoder from a graphics card (AGP/PCIE) to capture video from a software capture card (SAA7130/bt878)??
... or do I need to buy a capture card with mpeg encoder?
