hi, I would like to know if there are options that drive ZM two different connection speeds, such as for a LAN do not have control and internet only, you can use 512 kbits
hola, quisiera saber, si hay opcion de que ZM maneje dos velocidades de conexion diferentes, por ejemplo que para una LAn no tenga control y para Internet solamente , pueda utilizar 512 kbits
