I have to be missing something real obvious here, I have it all up and running but if I unplug the internet from the computer it is on, it stops.
Running firefox and live blue cherry cd install.
how do I get it to run free of the internet?
yup
kingofkya wrote:Just to make sure your opening the web page to http://127.0.0.1/zm right
Just tried it again, when I pull the plug the image stops and the time stamp stops.
but
when watching from another computer remotely I can unplug the internet from the dsl modem and it works fine, remotely.
I was planning to get a dual head video card and putting a monitor in an area where people can watch the cameras, and next to the computer itself.
My work around would be to get another computer and use that where I want to have the cameras monitored. I would rather not do that.
I get
eth0 Link encap:Ethernet HWaddr 00:15:f2:4c:95:db
inet addr:192.168.1.103 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::215:f2ff:fe4c:95db/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:195595 errors:0 dropped:0 overruns:0 frame:0
TX packets:256582 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:32403058 (32.4 MB) TX bytes:213568842 (213.5 MB)
Interrupt:23 Base address:0xe000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2625908 errors:0 dropped:0 overruns:0 frame:0
TX packets:2625908 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1878379327 (1.8 GB) TX bytes:1878379327 (1.8 GB)
When I run ifup lo it says its configured.
I think if I put the router and the host computer on a ups it will never lose power and my problems will be solved for short power outages, which is all I get usually.
Unless you see something there.
I've tried every search I can think of here so I think I'm missing something obvious.
