ZMC Stopping with exit status 255
Posted: Thu Aug 13, 2009 6:26 am
Hi guys, I've just built zoneminder and trying to get it to work with a capture card. The drivers are installed for the card, and I'm able to get a picture off it with webcam, so I do believe it's working. From the log files though, it appears that zmc is stopping almost instantly, so nothing's being captured. For the record, here's what I zmu -d /dev/video0 -q -v shows:
sudo -u www-data zmu -d /dev/video0 -q -v
[sudo] password for elijah:
Video Device: /dev/video0
General Capabilities
Driver: saa7134
Card: Sabrent SBT-TVFM (saa7130)
Bus: PCI:0000:01:08.0
Version: 0.2.14
Type: 0x5010015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Has tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
PAL
PAL-BG
PAL-I
PAL-DK
NTSC
SECAM
SECAM
SECAM-DK
SECAM-L
SECAM-Lc
PAL-M
PAL-Nc
PAL-60
Formats:
8 bpp gray (GREY)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
24 bpp RGB, be (RGB3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2 packed, YUYV (YUYV)
4:2:2 packed, UYVY (UYVY)
4:2:2 planar, Y-Cb-Cr (422P)
4:2:0 planar, Y-Cb-Cr (YU12)
4:2:0 planar, Y-Cb-Cr (YV12)
Crop Capabilities
Bounds: 704 x 480
Default: 704 x 480
Current: 704 x 480
Inputs: 3
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbdff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Tuner
Audioset: 00000001
Standards: 0xffbdff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbdff
Power on (X)
Signal detected (X)
This is what I'm seeing in zmdc.log:
08/12/09 23:05:19.090106 zmdc[18309].INF ['zmc -d /dev/video0' starting at 09/08/12 23:05:19, pid = 18502]
08/12/09 23:05:19.143064 zmdc[18309].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
And that repeats every few minutes. Now, if I run zmc manually as *root*, it keeps running; if I run it manually as www-data (the httpd user), it aborts instantly again. That would lead me to believe it's something with the permisions, but I even tried setting video0 to 777 and it still aborts when running under www-data. I appreciate any insight you all may have into this, I'd like to get it working. Thanks!
Driver: saa7134
Version: 0.2.14
Type: 0x5010015
Has tuner
Does not have radio
Standards:
PAL
PAL-BG
PAL-I
PAL-DK
NTSC
SECAM
SECAM
SECAM-DK
SECAM-L
SECAM-Lc
PAL-M
PAL-Nc
PAL-60
Formats:
8 bpp gray (GREY)
Crop Capabilities
Bounds: 704 x 480
Default: 704 x 480
Current: 704 x 480
Inputs: 3
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbdff
Power on (X)
Signal detected (X)
Input 1
Type: Tuner
Audioset: 00000001
Standards: 0xffbdff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbdff
Power on (X)
Signal detected (X)
