conexant FUSION 878a configuration problem
yaguarcito
Post by yaguarcito »
Sorry for my english....
I cant configure a conexant fusion 878a card, the computer detect the card in /etc/dev I have video0, video1, video2, video3. But when I configure the card in zoneminder I dont see anything.
there is a photo for my bt878a card
maybe its a compatibility problem.
please help me.
thanks
brainbug
Re: conexant FUSION 878a configuration problem
Post by brainbug »
yaguarcito wrote:I dont see anything.
Hi yaguarcito,
1st, stop zoneminder, then start "sudo zmu -d /dev/video0 -q -v" to see what signal your bttv-card supports?!
Restart zoneminder and add values zmu offers.
Cause most times, the BTTV card offers a "PAL"-signal with "RGB565"-color and resolution of "width 320 x height 240" and you need to choose "Video for Linux 1 (if you use 1.24!)
(I did not get such a card yet here in germany, so my help is just "guessing"!)
Hope, it helps
Ps: did you insert a configurationfile for your bttv card?
My card needs a file "/etc/modprobe.d/bttv.conf" with following content: "options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0"
Maybe, settings of this content will differ cause you are using 4 chips!
Without this file, i get funny pics like playing chess ;-)
yaguarcito
bttv.conf
when I put :
I have this message
Error, username and password or auth string must be supplied
and my bttv.conf is:
options bttv gbuffers=32 card=77 tuner=4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
I dont see anything still.
thanks for the help
cordel
Post by cordel »
Try:
options bttv card=133,132,133,133
Setup in zm:
/dev/video0(0)
/dev/video1(1)
/dev/video2(2)
/dev/video3(3)
/dev/video0(4)
/dev/video1(5)
You can assign video channels 0 to 15 to any of the four devices (video0 to video3) as you see fit:
/dev/video0 (0 to 15)
/dev/video1 (0 to 15)
Of coarse it's best to not load up to many channels on one device.
See kodicom 4400 for reference.
