Custom video creation
NokSuKao
Post by NokSuKao »
i want to create a video, but not directly from an event. I want to create the video from images with a appropriate date/time. i use a small php script to copy the necessary files in a folder. then i run ffmpeg and create a mpg video like this:
ffmpeg -y -i /videos/%03d.jpg /folder/video.mpg
i can watch the video, but it runs too fast. Are the input options for ffmpeg wrong?
thx for your help
NokSuKao
NokSuKao
Post by NokSuKao »
is there nobody out there who has an idea? I think it is the interlace/deinterlace option in ffmpeg?
But i don't get it work?
NokSuKao
kwire
Post by kwire »
NokSuKao,
Take a look a mencoder instead of ffmpeg. You can set the frame rate yourself, after you calculate it from looking at the appropriate record for the event in the Events Table.
HTH, Keith
