I have a client that has asked for a DVR type solution for their warehouse. They currently have 25 cameras all going to time lapse VCRs. My client has requested the ability to retain video footage for 30 days and they are hoping for 10fps. Can anyone in this forum give me any ideas on what type of hardware to recommend? Obviously, I'm going to need a pretty hefty CPU and quite a few video capture cards. Any recommendations?
Thanks,
Jason N.
25 cameras
Re: 25 cameras
Also, they have requested the ability to capture 5 audio sources as well? I'm assuming at this point I would have to have multiple ZM servers. Is it possible to tie the two servers together from the web interface?
Thanks...
Jason N.
Thanks...
Jason N.
Re: 25 cameras
Jason,
I'm sure more savvy users could give you better answers, but here's a few hints:
1) the 30 day requirement for 25 cameras at 10fps could be immense, exabytes, if you're recording constantly at full resolution with a low compression setting (on the order of 64 terabytes). If they're running VCRs, this might be what they expect. You may need to teach them about motion capture.
If you're doing motion triggering, there could still be a giant file requirement if there's a lot of movement (8 hour days, 5 days a week, movement in front of all 25 cameras is still on the order of 20TB). If the warehouse is mostly still, you could be talking about a few GB a month.... hard to tell.
You also have to contend with bandwidth issues. Even compressed, they're not trivial: 25MB/sec if all cameras are writing to the DB. ATA interfaces can handle the BW, but drives typically can't. You should probably consider hardware RAID 5 with at least 4 wide writing plus parity, that should give you the bandwidth you need. The RAID card should probably sit on a 64 bit PCI bus or PCI-X.
2) They probably want high uptime, given the application. This implies dual power supplies, UPS (or two, one on each power supply input in case one of those goes down - my server has one PS on the UPS and one on the wall); optimally RAID 1 (mirrored data, alternatively use the FTP function in ZM to offsite likely nasty alarms).
3) Processing: from my limited experience, 25 monitors isn't out of the question with typical high-pro server hardware, eg dual xeon 3.06s with a few gig of RAM.
4) You will need LOTS of RAM to store the buffers. You want something that can address it, like a 64bit processor or a PPC, but you might get out past the bleeding edge there. You can probably play with the buffer depths, but Xeon IVs in the right MoBo can address up to 16 GB. You're probably going to need it.
5) Capture hardware. I can't get my stupid pair of ImpactVCBs to work right, so I'm probably not the person to advise on this, but Linux Media Labs is likely to offer good support and this http://www.linuxmedialabs.com/product_d ... prodid=330 can do 8 streams on one board, probably 16 at 10fps multiplexed. You'd need two cards. I don't know if they play nice on a single PCI bus, but on a MoBo with dual PCI busses, you should be able to put one on each bus. I'd ask them. I tuner claims you can put up to 4 of their Spectra8 cards in a box. That's up to 32 full rate inputs, or 64 multiplexed ones. Pricy, but seems plausible.
Put your server box on gigabit and get a 32 port 100TX/gigabit switch, then hang 25 axis (or other netcams) cameras off it http://www.axis.com/products/cam_230/index.htm. This would provide a few advantages:
a) no long coax NTSC runs to get all noisy.
b) cams can be remoted on 802.11g for wireless links - all you need is AC.
Unfortunatetly, this is likely to be very expensive, and replaces their entire existing infrastructure.
-David
-David
Re: 25 cameras
Ok.... First of all... I think Motion Triggering would work the best. How sensitive are the settings in ZM to motion triggering?
I also agree that RAID 5 is the way to go with PLENTY of RAM.
Last but not least, I spoke with someone from Linuxmedialabs today. They are coming out with a 4 channel MPEG4 hardware compression based card in about a week or so running around $1350. They recommended putting (6) 4 channel cards in a system and storing everything as MPEG4 streams. The card doesn't currently work with ZM however they are expecting that will change within a month or so.
um
the first problem with that would seem to be the reduced (compressed) quality of mpeg4 vs. plain/uncompressed jpeg "stills".
second problem is it's still so much easier and standard to web-serve jpeg stills vs. any kind of stream.
we're considering a 6 cam server, capturing each at 5fps, storing to jpegs at 60% compression, showing 1 fps per cam on a web page, and cron-creating 15-minute "movies" using ffmpeg. that way, client can "see" real-time (at 1fps per cam), store "full quality" jpegs, and also have (a few minutes later, from any given moment) that moment included in a 15-minute "movie."
good luck with that beenden let me know how it goes
James Wilson
